RV.Net Open Roads Forum: Tech Issues: Furnace pops breaker after 30 seconds.
 > Furnace pops breaker after 30 seconds.
rjsurfer
North Carolina
Posted: 06/13/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
My new Cougar has it's first problem, the furnace runs(gets hot)for 30 seconds or so then pops the 15 amp breaker.
It doesn't make a difference if I run on Auto or manual fan, same symptoms.
I'm thinking the fan sounds a little strange, but that could be my lousy old age hearing??
Any ideas....no time to bring it for warranty service we're off on a camping trip Sunday.
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/13/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Mr Ron,
Without hinting about volts and amps, you are opening the floodgate for 500 different opinions with a correct answer hiding like a needle in a haystack.
Polite suggestion. It's new, right? Take it back to the dealer. Return home and pop a brewski. [emoticon]
Lynnmor
Red Lion
Posted: 06/13/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
First of many suggestions:
If the fan sounds strange, maybe it has interference or a dry/
tight bearing causing it to pull more amps.
rjsurfer
North Carolina
Posted: 06/13/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
Mr Ron,
I will be taking it to the dealer but we're heading off for 10 days near Asheville first, no time for dealer trip.
Ron W.
BFL13
Victoria, BC
Posted: 06/13/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
What do you mean by a "15 amp breaker"? Where is it located at the furnace or elsewhere? Usually "breaker" means 120v, so it is confusing. There are DC breakers though--resetting and those with buttons to reset them.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
time2roll
Posted: 06/13/19 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
120v breaker or 12v fuse?
675w Solar pictures back up
Harvard
51.6N 114.7W
Posted: 06/13/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a 120VAC breaker then it may be due to the increased load from the converter. The converter converts 120VAC to 12 VDC. 12VDC then powers the furnace.
Maybe the 120VAC 15 Amp breaker supplies power to something else along with the converter.
Old-Biscuit
Verde Valley
Posted: 06/13/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Clear up some confusion......
POST BRAND/MODEL of your Furnace
Most are ALL DC
Some are AC
Fan...
Auto/Manual....suggest you are doing that at the Wall Thermostat for A/C and Furnace (Cool/Heat)
Fan settings on thermostat control the Fan for A/C Unit only.
In AUTO the Fan runs when A/C Unit Runs
In Manual the A/C fan will run when furnace is runs....
All furnace controls/functions are via furnace circuit board when Thermostat Contacts Close (in Heat Mode)
SO Brand/Model AND which 15A breaker is tripping????????????
Chris Bryant
Arden, North Carolina
Posted: 06/13/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
If it’s the Atwood/Hydroflame 8500 series, either the breaker is bad or the blower motor is going. You can unplug the breaker and plug a 15 amp fuse in place. If it’s a bad breaker, that will work and be safe.
-- Chris Bryant
rjsurfer
North Carolina
Posted: 06/13/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, some more details.....
It's a Dometic DF series furnace controlled by the new InCommand system that Keystone is now installing.
The breaker that is tripping is a 12 volt 15 Amp breaker on the 12 volt side of the distribution panel. After 30 seconds it trips and the associated red Led light pops on. I can reset it by turning off the furnace control.
It doesn't matter if I run it Auto mode or Manual mode. Of course selecting manual mode for fan spèed also turns on the AC fan in the ceiling.
The manual does go into detail about some led error code faults but I'm not pulling the furnace out to read them.?...I'll leave that to the warrantee people at the dealer when we get back from our camping trip.
Ron W
