RV.Net Open Roads Forum: Travel Trailers: Towing with Jeep Wrangler
 > Towing with Jeep Wrangler
twodownzero
NM
Posted: 06/14/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Nobody has mentioned it, but the wheelbase of a Jeep, even the 4 door, is not safe for towing. It is as short or shorter than a regular cab/shortbed pickup. That is not good!
afidel
Cleveland
Posted: 06/14/19 08:41am Link  |  Quote  |  Print  |  Notify Moderator
camp-n-family wrote:
Dry weights don’t include options, propane or batteries etc. With those added you’ll be at your tow rating before putting anything in the trailer. Unfortunately Jeeps don’t make for good tow vehicles on anything bigger than a pop up.
I had a neighbor who tried what you’re considering. After 1 tow he started using his Caravan to tow with instead.
According to the federal standard the weight on the yellow sticker is to include battery, full propane tanks, spare tire if included and all factory installed equipment. In addition if the dealer installs equipment increasing the weight by more than 5% they are to install a new updated sticker. Now the yellow weight can and might vary from the "brochure weight", but that's up to the manufacturer, my trailer was within tens of pounds of the brochure weight.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
myredracer
Langley B.C.
Posted: 06/14/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
This is what I was going to add. The Jeep may also have tires that are not that great for highway towing. Have seen a few Jeeps towing a small R-pod and as is common, WDHs were clearly not adjusted properly.
'Course, a Hensley WDH will make it all good... [emoticon]
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
GrandpaKip
Flat Rock
Posted: 06/14/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I cannot comment on actual towing with a Jeep, because I’ve never done it.
Numbers however, are another story.
Both those campers will be over 400# tongue weight when ready to go. With a weight distribution system, real close to 500#.
That leaves you with about 800# for you, your family and anything else you put in there. You will probably be close to max.
I would be concerned with the Jeep’s tow rating because you will be at max or over.
I would not want to be at max on both those weights at the same time, pulling a sail through the air.
If you want to keep the Jeep, you will probably have to set your sights a little lower. You could also go to a Jeep forum to get opinions from people who have actual experience towing with one.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
profdant139
Posted: 06/14/19 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I hate to be discouraging, but this is not safe. The two biggest problems are (1) the big tail wagging the little dog, and (2) braking. A Wrangler can pull anything. But it can't stop everything.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Menanlg
Tucson, AZ
Posted: 06/14/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the help.
I will not be getting of the trailers I mentioned, I might look into a hybrid.
Does the tire type/size matter when towing? I have 35 inch tires.
Jebby14
Windsor Ontario
Posted: 06/14/19 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
softer rubber will hurt your towing. the soft tires with high sidewalls are not what you want for this. given your situation please take a long look at either a low profile popup or an upgraded tow vehicle.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Huntindog
Phoenix AZ
Posted: 06/14/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Well that changes things.... For the worse.
As tough as those tires make the Jeep look.... Reality is that they are an added stress to the jeep. The manufacturers ratings are now worthless. They need to be reduced... A LOT.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
camp-n-family
London, Ontario
Posted: 06/14/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
This is true if the OP is looking at a trailer on the lot and its actual yellow sticker. Most people when shopping are looking at brochures which tend to have substantially lighter “dry weights” that don’t tend include the above. Another sales tactic that gets the uninformed into trouble, much like 1/2 ton trucks with 12k tow ratings.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
drsteve
Michigan
Posted: 06/15/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
There is a reason more people tow Wranglers, than tow with Wranglers. And with 35 inch tires? I'd be looking at popups.
1991 Palomino Filly PUP
