RV.Net Open Roads Forum: UPDATE - F53 external fuel pump install FINISHED
 > UPDATE - F53 external fuel pump install FINISHED
MrWizard
Traveling
Posted: 06/13/19 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
it has Ford size Male quick connect fittings
https://photos.app.goo.gl/ZotLkM6kCprK9s5S9
Inlet Attachement: Quick Connect
Inlet Size: 5/16 "
Item Grade: Standard Replacement
Maximum Amperage (A): 5.0
Maximum Free Flow Rate (gph): 28.0
Outlet Attachment: Quick Connect
Outlet Size: 5/16 "
Package Contents: Electric Fuel Pump, Terminal Hardware, Extra Fitting, Seal, (2) Retaining Clips, (2) Splices, Instruction Sheet
Product Condition: New
Pump Location: External
Pump Type: Electric
Relief Pressure (psi): 99.0
Strainer Included: No
Voltage Rating: 12 vDC
Wiring Harness Included: No
Working Pressure (psi): 44.0
RELATED ITEMS
REPAIR GUIDES
Repair Guides for your Vehicle See Details
hope to install this this Sat
$84.xx plus Tax
order online pickup in store..same day
got it from autozone, several other places have it online for less $$
but nobody was closer or faster
* This post was last edited 06/28/19 09:30pm by MrWizard *   View edit history
Radiate The Happy
1997 F53 Bounder 36s
theoldwizard1
SE MI
Posted: 06/14/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Reviews on Amazon are not very good.
Check out Walbro inline fuel pumps
Also, be careful. If your chassis has "returnless" fuel, the fuel pump control module will cause the pump to run hot.
tiffy2000
NH
Posted: 06/14/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
let us know how it goes and post some pics of the install please
RLS7201
Posted: 06/14/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I'm curious, is there a place in the fuel line you can just slide it in? Or do you have some new fittings to splice in the fuel line?
Richard
If I had a dollar for every girl that found me unattractive,
they would eventually, find me attractive.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
MrWizard
Traveling
Posted: 06/14/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I could slide it in, by replacing the fuel filter
But the plan is couple the filter output to the pump input by fuel hose
Then connect the pump output to the quick connect line going forward that is/was on the filter output
I bought thick fuel hose supposedly rated for throttle body injection pressures
Pirate
Northeast Tennessee
Posted: 06/16/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Get this done yet?
MrWizard
Traveling
Posted: 06/16/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
not yet
try again tomorrow, things keep happening to get in the way
i did get under and start figuring out how to run the wires
and i also unplugged the O2 sensor, and soaked the threads with 'Aero Kroil' penetrate, so i can replace it
MrWizard
Traveling
Posted: 06/19/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I ran the wiring for the pump
Pump is not yet installed
Bump in the road
Bundy fitting is correct length from ridge up to end of hitting
But...behind the ridge back to pump is not the same length as OEM FORD FITTING/nipple
Careful measuring shows not enough room to insert disconnect tool if pump is coupled to Ford fuel line quick connect fittings
Will have to go with plan B, and use pieces of fuel hose to connect system together
MrWizard
Traveling
Posted: 06/26/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
just an update, project NOT yet completed
its been one 'error' (on my part) or one physical mechanical problem after the other
when i planned and started this project, it would have been nice to know that this was available, cut to needed lenght
this one is 3/8 but i found 5/16 at the parts store
quick connect to hose/tubing
auto parts stores have them in stock,
i could have used almost any pump with the correct pressure and flow rate and been done already (instead of looking for one that came with quick connect ends
as it is i'm going to need it anyway
MrWizard
Traveling
Posted: 06/28/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
install FINISHED
short local surface street test drive
running GREAT !!!
[emoticon]
upper left quick connect is line from fuel tank, originally connected to input of fuel filter, now connected to fuel hose that loops around to inlet of fuel pump mounted above filter
hose on output of fuel pump loops around and connects to input of fuel filter
output of fuel filter remains stock , connecting to OEM female quick connect OF the fuel line going forward
* This post was last edited 06/28/19 10:35pm by MrWizard *   View edit history
