RV.Net Open Roads Forum: UPDATE - F53 external fuel pump install FINISHED
 > UPDATE - F53 external fuel pump install FINISHED
MrWizard
Traveling
Posted: 06/29/19 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Yeah I need a few more wire ties, to clean up the wiring install
Will get under there today
Radiate The Happy
1997 F53 Bounder 36s
TNGW1500SE
Oliver Springs TN
Posted: 06/30/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a little lost as to why I'd want an external fuel pump. Is it a replacement so you don't have to drop the fuel tank? I had to drop mine. Not because of the pump but due to the generator fuel line cracking. It was a job to say the least. I thought about sticking in a new pump while it was out but decided if it ain't broke, don't fix it.
Pirate
Northeast Tennessee
Posted: 06/30/19 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting how people think. I plan on purposely dropping my tank and replacing my perfectly good pump (and generator line) this fall. Why? I would rather do it on my terms than someone else's. Nothing wrong with your philosophy. To each their own.
MrWizard
Traveling
Posted: 06/30/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, to avoid dropping the tank
Pump was dying, causing lots of engine run problems from lack of fuel to the engine
tiffy2000
NH
Posted: 07/02/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
For some reason I can't see your picture of the install
MrWizard
Traveling
Posted: 07/02/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmmm
Nobody else has said anything
This particular photo is on my Google photo's
I hope it is posting normally for EVERYBODY
Heisenberg
West Texas
Posted: 07/02/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
me too no pictures
2013 Winnebago Sightseer
2017 Colorado
TNGW1500SE
Oliver Springs TN
Posted: 07/02/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I thought that may be the case. I dropped mine in my garage with two floor jacks, air tools and good lighting. It was a job. My tank was half full and it took all of the morning and part of the afternoon to get the fuel pumped out using the generator pump that I hotwired. Filled all my cars and all my gas cans. Mine was designed so the back jacks were in the way of one of the straps. That sucked.
Be sure and look at that generator fuel line. Like I said, mine was cracked from the generator all the way to the top of the tank. I could have spliced it but that would have left about a foot of old line on top of the tank so I pulled it down and replaced it all.
TNGW1500SE
Oliver Springs TN
Posted: 07/02/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I owned an auto repair shop for years and have replaced countless fuel pumps. Just because it's new, doesn't mean it's good. Trust me. I've put brand new pumps in and they were defective. With that said,,, If I were doing it just because mine had some miles on it, I'd be sure and get a factory one. Aftermarket ones are junk.
PS: Use good quality stainless hose clamps on the generator hose.
MrWizard
Traveling
Posted: 07/02/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
No Cutting OEM fuel lines, install external electric fuel pump
[image]Click For Full-Size Image.
* This post was edited 07/02/19 09:49pm by MrWizard *
