RV.Net Open Roads Forum: UPDATE - F53 external fuel pump install FINISHED
 > UPDATE - F53 external fuel pump install FINISHED
tiffy2000
NH
Posted: 07/03/19 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for reposting pic, pic worth a thousand words. Where did you tie your wires into ?
MrWizard
Traveling
Posted: 07/03/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
In the battery control center, I found an unused dash fan connection with 15 amp fuse, powered only with key in the on position
Radiate The Happy
1997 F53 Bounder 36s
T18skyguy
Eugene, OR
Posted: 07/03/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
My fuel pump went out and I used an ATV lift to bring down and raise the new tank. What happened is when I went to undo the bolts to remove the pump, every one of them snapped off which mandated a new tank. The guy I bought the tank from said that bolts snapping off is the single biggest problem with replacing the in tank pumps. You may have dodged an expensive bullet by not pulling the tank.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
Pirate
Northeast Tennessee
Posted: 07/04/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
TNGW1500SE wrote:
Mine was designed so the back jacks were in the way of one of the straps. That sucked.
My HWH jacks are like that. I can't even see how they tightened some of the nuts. Any tips on how you handled this?
Pirate
Northeast Tennessee
Posted: 07/08/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Ford tech warned me a while ago about the bolts said to make sure and pre-soak and turn forward/backward in small amounts.
Heisenberg
West Texas
Posted: 07/08/19 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same job at one time. You have done well.
The only recommend I have is to use a relay coil to crash switch n/o to fuel pump. The crash switch needs to disable the 40 psi fuel pump in case of crash. It is located on the steering column.
2013 Winnebago Sightseer
2017 Colorado
MrWizard
Traveling
Posted: 07/08/19 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
i think mine is on the floor between the steering column and the dog house
but i will look again
no drivers door hard spot to get out of, once i'm squeezed in there
Pirate
Northeast Tennessee
Posted: 07/09/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Reviews on Amazon are not very good.
Check out Walbro inline fuel pumps
Also, be careful. If your chassis has "returnless" fuel, the fuel pump control module will cause the pump to run hot.
which of those Walbro's is for the F-53?
Edit: Nevermind. I found the cross-reference chart.
* This post was edited 07/09/19 04:24pm by Pirate *
Heisenberg
West Texas
Posted: 07/10/19 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Walbro
MrWizard
Traveling
Posted: 07/10/19 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
its been many years since i have seen a factory production gasoline vehicle that was 'returnless', i think my 92 pace arrow 454 even had a return line
i know i saw a line on this one, that looked to be a return line
its all part of the fuel economy and smog regulations
