RV.Net Open Roads Forum: Upgrading to electric stabilizer jacks
 > Upgrading to electric stabilizer jacks
hfd45c9
Posted: 06/14/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I am currently adding Lippert electric stabilizer jacks to our toy hauler. What is the correct way to wire the 12V DC motor to my back up batteries. They are wired in series. Any suggestions are appreciated.
myredracer
Langley B.C.
Posted: 06/14/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
First, check Lippert's wiring diagram. There should be a mini-breaker for each jack (like the one's in an A-frame) plus a fuse as I recall. Our breakers are mounted on the side of the frame I-beam next to the jack. Fuse is for short circuit protection and breaker is for overload protection. I think some manufacturers don't install both though (big cost savings??). On a retrofit, you can run new pos. wire up to the A-frame and use an in-line fuse there (weatherproof).
If you want to go a step further and get fancy, you could get rid of the metal 4x4 box in the A-frame, use a watertight PVC box and then install fuses & breakers in it along with splices, which is what I did.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
ependydad
Here and there
Posted: 06/14/19 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Just understand that they're less stable than anything you're replacing now.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Lynnmor
Red Lion
Posted: 06/14/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
My thought was that the title is wrong and should say: "Downgrading to electric stabilizer jacks."
myredracer
Langley B.C.
Posted: 06/14/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
They shouldn't be allowed to call them "stabilizers"... [emoticon] Only thing they're good for is convenience and "our TT is better than yours".
What you'll need is a set of BAL (or other brand) stabilizer struts for your "stabilizer" jacks. We've got 'em and they help a lot.
Hammerboy
Zeeland, MI
Posted: 06/14/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
True, our fifth wheel has them and when they **** out someday I will not be replacing them not to mention they are slooooww.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
ependydad
Here and there
Posted: 06/14/19 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Dan
I know a U-Haul store in Lousiana that'll make short work of those rear stabilizers if you want to just go ahead and smash the s$#@@t out of them.
[emoticon]
beemerphile1
Ohio
Posted: 06/14/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
The electric stabilizers are also slower than using a cordless drill with manual stabilizers.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
crcr
US
Posted: 06/15/19 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Well, our experience with electric stabilizer jacks is positive. They came on the 3 yr old TT we bought, and we have used them for 5 years now with no problems.
On our previous TT's, I did use a cordless drill for the jacks, so I have that for comparison. I probably wouldn't pay a lot extra for electric stabilizers, but I like the convenience.
hfd45c9
Posted: 06/17/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
I already have the wiring diagram/in line fuse etc. I just want to be sure I am wiring to the back up batts. correctly. Do I connect pos./neg. to terminals on one batt. or do I need to put pos. on one batt. and neg. on a different batt.?
