RV.Net Open Roads Forum: Tech Issues: Microair vs Hyper Engineering?
 > Microair vs Hyper Engineering?
GordonThree
Northern Michigan
Posted: 06/15/19 12:07am Link  |  Quote  |  Print  |  Notify Moderator
I was considering the LC2400 model, which offers 2400 volt amps on a 20a circuit.
It's not the full 3600va of the Hughes or Sola.
From the load panel on my unit it should work, based on FLA of the compressor and blower.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
SpeakEasy
Western New York
Posted: 06/15/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Can't comment on the Hyper Engineering product, but I'll throw this into the analysis: customer service. The folks at Micro Air are super to work with. Very customer-service oriented. They'll answer all your questions quickly and in a helpful, friendly way. If that matters to you. It does to me.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
2oldman
Ca
Posted: 06/15/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
The Honda's inverter programming seems to handle surges better in general, faster to bring up the throttle maybe?
Mine do fine.
pianotuna
Regina, SK, Canada
Posted: 06/15/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
The Sola Basic is 4000 VA, so the perfect size for a 30 amp RV. It has 3 levels of boost, and one of buck. It has no surge protection, but it is easy to add some. It is easy to adjust the boost levels.
The only fly in the ointment is getting one. A wonderful RV'er transported one for me to Canada.
The LC2400 has 2 levels of boost and one of buck. Cost is about $300 Cdn on Amazon Canada.
Regards, Don
GordonThree
Northern Michigan
Posted: 06/15/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I'd surely be happy with more volt-amps but curious if 2400 is enough. For me the unit is $200 USD through Amazon, with free overnight delivery.
Looking at the Hughes, it seems to only have one level of boost, and no buck?
GordonThree
Northern Michigan
Posted: 06/15/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
-Speak
Very good point. I think the popularity and customer service aspect is worth the extra cost.
SpeakEasy
Western New York
Posted: 06/15/19 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
-Speak
A year or so ago there was a discount code available if you went to Micro Air through the Gone with the Wynns blog website. Might have been a $25 coupon, if I remember correctly.
(Act fast before the mods remove this post for soliciting. Even though I have no skin in the game.)
-Speak
pianotuna
Regina, SK, Canada
Posted: 06/15/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hi GordonThree,
If I remember correctly, Hughes does a tiny boost (such as 116 to 118). Then a further 10% boost when input voltage drops below 113. It continues to boost 10% right down to 90 volts. There is no buck.
I don't think buck is too necessary unless you are heading to Mexico.
I have tweaked my Sola Basic to cut in about 3 volts higher than the OEM 110, 100, and 90. I may be trying it with my Yamaha generator on 2019 06 21.
3 tons
CA.
Posted: 06/16/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
The Easy OR Sure start can certainly help, yet their can be other variables, such as Ambient temperature, elevation, whether or not in the ‘eco’ mode, and age of unit...
My neighbor and I have the exact same Coleman 11 kbtu Mach 1 P.S. but his is new and mine is 10 years old...His uses about 2amps less than mine...
This is why after beginning with the easy start, I now prefer the Autoformer which makes the unit operate in eco without a hitch...
pianotuna
Regina, SK, Canada
Posted: 06/16/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons,
If I were to start over I would not bother with the Easy or Sure. I'd just use the autoformer.
