RV.Net Open Roads Forum: Tech Issues: Microair vs Hyper Engineering?
 > Microair vs Hyper Engineering?
GordonThree
Northern Michigan
Posted: 06/14/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
The Microair Easy Start is $299, the Hyper Engineering SureStart is $225 through their Ohio partner BriskHeat.
SureStart is five wires, Easy Start is four. Both appear to be triac based "computerized" units.
Any pros or cons for either unit? The Easy Start seems a lot more popular in the RV community.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
philh
Belleville MI
Posted: 06/14/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
EasyStart works and was an easy install. Can't comment on the other unit.
2oldman
New Mexico
Posted: 06/14/19 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure why this is needed. Can't most inverter gens start the air? Or is the goal to smooth out the inrush?
GordonThree
Northern Michigan
Posted: 06/14/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
My blue 2000w can't start my 13.5, I've added the hard start kit. When I parallel two of the blue 2kw they will start and run, but only at full throttle. In eco they stumble on the inrush of restarting the compressor.
3 tons
NV.
Posted: 06/14/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have both, the Sure Start and the Hughes Autoformer...
Of the two, the autoformer immediately kicks in and does the best job of overcoming voltage sag when running the air cond via the Honda 2000i in eco mode (allowing honda time to respond), plus provides surge protection...The autoformer addresses the sag issue where the air cond caps are not the actual root cause.
https://tweetys.com/hughes-autoformer-rv2130sp---30-amp-autoformer-w-surge-protection.aspx
3 tons
GordonThree
Northern Michigan
Posted: 06/14/19 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
The Honda's inverter programming seems to handle surges better in general, faster to bring up the throttle maybe?
I know Yamaha has a 2nd generation 2kw now with improved surge handling
I was looking at a TrippLite auto transformer, maybe the way to go, as it will multitask, helping at busy parks with sagging shore voltage.
philh
Belleville MI
Posted: 06/14/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
My Westinghouse 2500 would give up and roll over trying to start my 15k AC. With MicroAir unit installed, I can leave the W2500 on eco mode and it spools up nicely and handles the AC startup.
philh
Belleville MI
Posted: 06/14/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Microair video showed the hard start actually pulled more start up amps then the stock AC.
pianotuna
Regina, SK, Canada
Posted: 06/14/19 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
A few folks are now using autoformers between their generators and the RV. The results are encouraging allowing eco switch on and smaller wattage units.
I had better results previous to the microaire with the Sola Basic. I've tweaked the cut in voltage to a higher setting. So far I've not had a chance to test this.
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 06/14/19 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi GordonThree,
Did you find a Tripplite that had a high enough VA rating to run a roof A/C?
