RV.Net Open Roads Forum: Tech Issues: Microair vs Hyper Engineering?
 > Microair vs Hyper Engineering?
time2roll
Posted: 06/16/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
I was considering the LC2400 model, which offers 2400 volt amps on a 20a circuit.
It's not the full 3600va of the Hughes or Sola.
From the load panel on my unit it should work, based on FLA of the compressor and blower.
I considered this for just the A/C branch circuit. Never followed through.
I have a Frank's booster but I don't run the air unless I have utility power.
675w Solar pictures back up
3 tons
NV.
Posted: 06/16/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
3 tons,
If I were to start over I would not bother with the Easy or Sure. I'd just use the autoformer.
Me as well, what I prefer is that the autoformer corrects the voltage sag rather than meter power out through the sag condition...I believe it's this sag condition that is the root cause.
3 tons
philh
Belleville MI
Posted: 06/16/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Does an autoformer have the ability to start an AC unit when running on a 2000 watt generator?
3 tons
NV.
Posted: 06/16/19 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
It’s hard to say for sure because of the several variables that I previously mentioned, however in my case (at 4,800’ elevation, 80 deg/f,10 year old air unit) voltage sag appears to have become a non-issue because the generator while in the eco mode responds smoothly and steps up RPM quickly to the increased load...
Having said that, because each case is somewhat different I also consider the comments of other posters to be highly reliable - Understand that the autoformer just provides a different strategy - JMHO
3 tons
pianotuna
Regina, SK, Canada
Posted: 06/16/19 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I can't say for certain, but I can say that before the Microair, when starting on shore power that the Sola Basic "kicked in" in well under 1/3 of a second. Post microair, that no longer happened.
As a result I've tweaked the autoformer to cut in at 113 instead of 110. I'll be testing it on 2019 06 21.
Regards, Don
jharrell
Safety Harbor, FL
Posted: 06/17/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure how an autoformer would help, it increases voltage by increasing current on the input side, so your locked rotor current draw just went up on the generator.
In the end power is the same, the voltage sag is due to the large amount of in-rush current to the motor.
A soft starter like a Easy-star ramps up voltage slowly to motor limiting current in-rush.
Would be interesting to know how a autoformer can help the situation, it actually seems like it would make things worse by drawing more current from the generator.
BTW My Easystart works great on my Coleman 15k.
2016 Winnebago Vista 31be - Blue Ox Rear Track Bar - Centramatic Wheel balancers
2016 Jeep Wrangler Unlimited Rubicon Toad - Readybrute Elite Towbar
philh
Belleville MI
Posted: 06/17/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
That was my thinking as well.
GordonThree
Northern Michigan
Posted: 06/17/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
I might get the transformer to use in parks with low voltage.
I think I'll stick with running my twin Yamahas for times when I need off grid AC. Together they provide 26 amps so I can also charge the battery bank a bit at the same time.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
