RV.Net Open Roads Forum: Tech Issues: DIY MC-4 Connectors- 2nd Photo Added
 > DIY MC-4 Connectors- 2nd Photo Added
BFL13
Victoria, BC
Posted: 06/15/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
How many inches of pigtail do these panels provide?
About 39 inches. Go to the right for drawing of the panel I just got. Same for the 255w panel I got a few months ago. The good thing with that is they can stick out from under the panel after you lay it down, so you can do your wiring hook ups after.
http://www.wegosolar.com/products.php?pr........DH%252d60P%252d275-Solar-Panel-275W-Poly
Side note--panel efficiencies are improving. Guy said they have a new way to cut the silicone so there is less waste and the cells fit together better so the panel can be the same area with more watts---If I got that right. This 275 at 17.8% is very close to the same size as the older 255 at 15.5%. I suppose that matters if you are doing a big array.
* This post was edited 06/15/19 09:30am by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
bpounds
Sophmore Brain...
Posted: 06/15/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
bpounds wrote:
I guess I was more ignorant than intrepid. I dug right in and made all my cables. Soldered all the pins. Amazon has all these connectors too.
Are you supposed to solder the wire end and pin end after crimping with the fold over tabs and squeezing them?
--Some panels have sealed junction boxes so you can't open them up to put your own wire in.
Soldering is not required, and probably would not be if you purchased madeup cables. Which makes homade better IMO.
Also, I don't believe those you linked cannot be disassembled. It just takes a certain tool to do it. You are right that it is easy to get pins in the wrong body.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
2oldman
New Mexico
Posted: 06/15/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
In that case I cut the pigtails to a few inches and glue on my own terminal block.
landyacht318
Near a large body of salty water
Posted: 06/15/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
steveh27 wrote:
I use SAE connectors.
I went this route around 12 years ago, getting many with 10AWg and 18AWG leads. The awg should be in quotes as 10AWg is actually closer to 12AWG.
I had a pair on my 25 amp 'smart' charger and they would get so hot passing this much current for a half hour I could smell hot plastic.
This just got worse with time, as the barrels would open up and one would have to tweak the connection to get contact.
I also hated how one could unintentionally reverse the polarity so one had to label input' and 'output'.
All my 12v SAE connectors and their pigtail are now in a plastic bag to be given away, and have been replaced with Anderson Powerpoles which are largely trouble free, but hardly perect.
BFL13
Victoria, BC
Posted: 06/15/19 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Here you can sort of see the little spreaders on the pin that go in past a catcher inside the housing. Once past that catcher ring, you can't pull it back out, because of the spreaders (whatever they are called)
The white piece is to keep the end from squeezing in too much when you screw on the end piece.
Also shown is an actual MC-4 on a cut-off pigtail from a previous panel I did. It is all glued together so there is nothing to undo. You can use the cut off one but would need to wire nut or somehow otherwise connect the wire to another wire.
First step is to mark the positive panel pigtail near its MC-4 with red tape. Once the panel is lying down, you might not be able to tell which is which of the pigtails sticking out.
EDIT--OOPS! The new panel has different MC-4s on its pigtails, that do unscrew. (I didn't unscrew them all the way to see inside.)
* This post was last edited 06/16/19 10:54am by BFL13 *   View edit history
beemerphile1
Ohio
Posted: 06/15/19 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
I suppose everyone knows about these except me until today, but in case anybody does not, here it is...
http://www.wegosolar.com/products.php?pr........=MC%252dMALE-MC%252d4-Male-Clip-with-Pin
I hope you didn't pay that amount. I bought five pairs of the Renogy brand on Amazon for $10.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
BFL13
Victoria, BC
Posted: 06/16/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Added second photo to above post showing a different panel MC-4
