RV.Net Open Roads Forum: Travel Trailers: cleaning before eternabond
 > cleaning before eternabond
jy
south east mich.
Posted: 06/14/19 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Im going to eternabond my front and rear seams between the caps and roof.What works best to clean the cap and roof before applying the eternabond?
99 Coachmen 322QB, Ford V10,18 foot Load King open trailer, 2007 Mustang GT Toad, Gibson exhaust,Royal Purple lubricants.Recently retired and planning on doing more RV'ing.
IAMICHABOD
Sunny So Cal 90713
Posted: 06/14/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Use something "Hot" something that evaporates fast I like to use Acetone it is what I have always used with out any problems and have had no failures when I did the very same seams.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 06/14/19 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
I use Brake Kleen. It removes the dirt, dries quickly and leaves no residue.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
CincyGus
Cincinnati
Posted: 06/15/19 01:02am Link  |  Quote  |  Print  |  Notify Moderator
Most videos I've seen applying Eternabond show using acetone. I have seen a few use windex also.
Eternabond makes a cleaner also if your wanting what they recommend. The acetone will be significantly cheaper and has been used for years without reports of any problems.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
eHoefler
ozark mountains
Posted: 06/15/19 04:19am Link  |  Quote  |  Print  |  Notify Moderator
The instructions that came with mine stated to use either Lacquer thinner or Gasoline.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
gbopp
The Keystone State
Posted: 06/15/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I've used Acetone and Lacquer Thinner. They both work well.
Use a roller to apply the Eternabond. I like the steel roller, some people like the wooden roller.
winniman
muskoka Ontario
Posted: 06/15/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
The eternabond I bought said to use mineral spirits to clean the area. I have used rubbing alcohol with good success. It was I had in stock.
ReneeG
Meridian, Idaho
Posted: 06/15/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
We used Eternabond's recommended cleaner in the link in this post. It worked well. Our thought was that using the manufacturer's recommended cleaner would be best for adhesion. So far, so good, 5 years later.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
JIMNLIN
Oklahoma
Posted: 06/16/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
This as we have no idea what material is on your roof. Same with those that say they use XYZ on their roof material.
Contact your units roof material mfg or the trailer mfg and ask for their recommendations on what to use or not to use.
Most roof materials are compatible with Eternabond cleaners.
And follow their instructions.
And finish the job like the pros with a sealant around the Eternabond edges.
