RV.Net Open Roads Forum: Truck Campers: Electric Jacks
 > Electric Jacks
Geewizard
E. Washington
Posted: 06/16/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
I've had exactly one motor failure on my Happijacs since 2004. That's the only issue I've had.
Proper maintenance is the key with ANYTHING mechanical, IMHO.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
Mary Kitchen Roast Beef Hash
220W solar, MPPT controller, LED lights
Library Books
Wave 3 Heater
sbryan@vtbryans.com
Vermont
Posted: 06/16/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I lost 1 HJ motor early on and otherwise they have been fine. I think it's a **** shoot on what is best. Remember that happy people don't post but people with problems do so the comments are always skewed. I suspect there are lots of happy HJ people who don't say anything (me included). One motor failure, covered under warranty, was an easy replacement and has worked fine since. JMHO
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
otrfun
Desert SW
Posted: 06/16/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Is it possible HJ outsells the other brands? If so, it would stand to reason there might be more complaints.
Without knowing how the number of HJ problems/complaints compare proportionally with other brands makes it kinda hard to know whether HJ is actually more problematic or not.
jimh425
Western MT
Posted: 06/16/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure who sold the most, but from what I’ve heard here, it seemed Atwood had better customer service. I think that makes people more tolerant of failures.
My 13 year old jacks have had two issues. One remote controller died at about the 2-3 year mark. The switch to turn them on is intermittent. A shot of WD40 seems to get it working again.
joerg68
St. Ingbert, Germany
Posted: 06/17/19 12:28am Link  |  Quote  |  Print  |  Notify Moderator
The old HJ motors were a bit sensitive to water intrusion. The new design - which looks a bit like the old Atwood - may avoid that issue, as the motors now sit at the top of the motor head.
FWIW, I had 5 HJ motors on my Outfitter Apex. One for the roof, four for the jacks. One of the jack motors was seized and thoroughly corroded after the second winter and had to be replaced. The jacks themselves and the other motors were fine.
Replacing a HJ motor is a simple DIY job, but not cheap.
TxGearhead
Posted: 06/17/19 06:54am Link  |  Quote  |  Print  |  Notify Moderator
For preventive maintenance on my Happijacks I found 1/2 gallon plastic buckets to cover the motors. Hopefully keep water intrusion to a minimum. Wind will blow them off. I used twist ties to secure the bucket bail to the motor wires.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Glacier D
Port Orchard, Wa
Posted: 06/17/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
My experience with HappiJac is that they are pure garbage. Granted I used my camper in the winter where the roads are salted, owned my camper 10 years and on my 3rd set of jacks and motors, 2nd motherboard and second remote. I have the newer 4800s (zinc plated) and they are just as rusted as my old 4500s and 4600s.
Don't drink their koolaide, their jacks do not hold up!
2011 Dodge Ram 3500 4X4 Crew Cab/LB, Rancho RS9000XL, Stable Loads, Superhitch and FastGuns. 2009 Eagle Cap 1050, Hickory interior with on-board generator, A/C and Honda EU2000
Geewizard
E. Washington
Posted: 06/18/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I use gallon-size plastic bags.
Good to see another Go-Devil Surface Drive owner on here.
hedge
Airdrie, Alberta, Canada
Posted: 06/18/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I had one motor go bad. Since then I've covered the motors with 3-gang electrical box gaskets year round. They probably don't look that great and maybe it's placebo, not sure... but haven't had a problem since.
2017 F350 Platinum DRW
2013 Adventurer 89RB
K Mac
Lower Hudson Valley N.Y.
Posted: 06/18/19 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
7 yrs. so far and no issues with my HJ's,I put a few drops of oil in top and spray legs with some silicone every trip. I do not use a lot, just enough to do the job. When I would use too much oil I could see the excess all over the legs, as I said a few drops.
 > Electric Jacks
