RV.Net Open Roads Forum: Travel Trailers: Do airbags help?
 > Do airbags help?
Snomas
Sedona, AZ
Posted: 06/15/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'm pulling a 22 ft TT for the 1st time w/my 2018 F150 2 rear WD. I have a Anderson WDH. Has anyone added air bags to their truck and does it help that much. I have to really tighten the chains to bring the rear end of the truck up so the front end comes down and doesn't float when towing.
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
goducks10
There
Posted: 06/15/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Air bags don't transfer weight to the front. They'll stiffen the rear but that still doesn't change the dynamics any.
https://www.youtube.com/watch?v=XBZu39pQ8Gg&feature=youtu.be
1320Fastback
Vista, Ca
Posted: 06/15/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Its going to be one heck of a rough ride with airbags, especially if you pump them up to raise the rear end more than 2" or so.
Be better to remove tongue weight from the trailer.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
Hearst San Simeon State Park
Posted: 06/15/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
“I have to really tighten the chains to bring the rear end of the truck up so the front end comes down and doesn't float when towing.”
I believe you are seeking to be level for looks. And TV’s your payload is? Must be a very light duty F150. Air bags won’t increase your payload. “Shifting” weight doesn’t increase payload either.
Winnebago 2101DS TT & 2019 Chevy Silverado 1500 LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - (MOS 1542 & 1560)
beemerphile1
Ohio
Posted: 06/15/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you are overloaded, air bags won't change that.
2018 Keystone Cougar 26RBS
Bob/Olallawa
Kitsap Co, WA
Posted: 06/15/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
You really need to have the right hitch componets for the weight and know how much you are really transfering back to the front of the tow rig. Air bags mostly cause more problems than they do good. You have to set them up before hitch set up is done.
Welcome to my home, that door you just broke down was there for your protection not mine.
JIMNLIN
Oklahoma
Posted: 06/15/19 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Air bags will help overall. However I wouldn't depend on the bags to transfer weight. Bags can lesson rear spring compression and rebound
I pull a 10k car hauler with a 7400 lb blue tractor with the wifes 1500 chevy. I went with Sumo springs which helps stiffen up the rear spring pack. What I like about the Sumo is I can remove them in about 3 min when I don't need them for a stock ride. I thought about bags but for my use 6-7 times a year didn't make cents/sense for me.
My Husky Centerline TS WD hitch brings the trucks front down to normal ride height.
MitchF150
Puyallup, WA
Posted: 06/16/19 01:25am Link  |  Quote  |  Print  |  Notify Moderator
How are you setting your WD bars on the trailer? Do you just plop the tongue on and then try to set the WD bars, or do you plop the tongue on and then LIFT it up with the tongue jack to get the weight off the hitch and then set the bars?
Good luck!
Mitch
Lynnmor
Red Lion
Posted: 06/16/19 01:26am Link  |  Quote  |  Print  |  Notify Moderator
Ford manual says to return the FRONT to 1/2 as much as it changed before and after the trailer is on the ball. If the rear is then sagged too much, add additional spring to the rear (air bags for example) to return the rear to a reasonable height.
GrandpaKip
Flat Rock
Posted: 06/16/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
The chains are supposed to be tight. How much are you compressing the urethane bushing? Should be about 1/4” or so, if I remember correctly. I raise the tongue and truck with the jack to make it easy to adjust the tension nut. I have about 600# on the tongue and have no problem returning the front end to spec.
Do you know the tongue weight?
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
 > Do airbags help?
