RV.Net Open Roads Forum: Travel Trailers: Do airbags help?
 > Do airbags help?
twodownzero
NM
Posted: 06/16/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
It doesn't sound like you would benefit at all from airbags. Is your entire truck and trailer level with the bars on? Maybe some time with a tape measure and some adjustments are in order.
GrandpaKip
Flat Rock
Posted: 06/17/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Hey folks, he has an Andersen hitch. It doesn’t have bars and uses a tensioned chain instead. Whole different animal than hitches with bars.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Snomas
Sedona, AZ
Posted: 06/17/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
GrandpaKip wrote:
The chains are supposed to be tight. How much are you compressing the urethane bushing? Should be about 1/4” or so, if I remember correctly. I raise the tongue and truck with the jack to make it easy to adjust the tension nut. I have about 600# on the tongue and have no problem returning the front end to spec.
Do you know the tongue weight?
Tongue wt is approx 550 # and I can't get the front end down to spec, I'll try more tension on the chains to see if that helps. I get a fairly smooth towing on smooth roads, but it can bounce on a rough road. Is that normal?
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
GrandpaKip
Flat Rock
Posted: 06/17/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I get less bounce with the Andersen than I did with my other WD, but some roads still cause porpoising. Sometimes, changing speed helps.
When I set them up for the Silverado, I used the tongue jack to raise everything to make it easier to adjust the nut. Then I tightened it one turn, let it all back down and remeasured. Kept it up until the truck sat properly. I did this with the truck unloaded. If I have a lot of stuff in the bed, I’ll usually make another half turn from “normal”.
The chains on mine are so tight that they feel like a solid piece of steel.
 > Do airbags help?
