RV.Net Open Roads Forum: Installing base plates in a 2006 Grand Vitara
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Installing base plates in a 2006 Grand Vitara
D.E.Bishop
Eagle Rock, CA
Posted: 06/15/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I think I mentioned earlier that my 1995 Suzuki Sidekick met it’s demise. Two pistons at the top of their respective cylinders. Thought about a used engine for $1400 plus labor to change out or looking for another towed. There were several other things that made me decide to go for a different one and I finally found a 2006 Grand Vitara. They are nice little utes and I think I got a good deal on it.
Of course it did not have any base plates and it is not wired for lights. Not too big a deal for a shade tree mechanic like myself, NOT! I have always had Roadmaster base plates and tow bars. It’s just the way the other two toweds came. So I read the installation instructions and decided that the installation wouldn’t be a big deal. Boy was I wrong.
Stripping down the plastics on the front end was easy, I followed the directions and then I started the install. I have no idea how Roadmaster did the install in 2.5 to 3 hours. This is really my third baseplate install and the directions for the other two were spot on, not this one. The instructions said to remove the two mounting bolts for the windshield washer tank, Wrong. There were three bolts, two of which were hidden and required removing the mounting bracket for the CPU and raising the CPU out of the way. Of course that required removing the left head light assembly. So instead of two bolts to be removed, there were ten and one very weird mounting bracket.
On the other side, the instructions said to remove an expansion chamber in the air intake for the engine. Nope, I had to remove the entire intake, on the right side of the engine, including the air filter.
So five hours later, I was done with the install but not cleaning up and storing the tools in their proper places. No way one guy can do that in just 2.5 to 3 hours.
Monday will be the installation of the light cable, diodes and four wire socket. I sure hope that it is as simple as pulling the cable from front to rear and installing the diodes.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
lryrob9301
Mid-Atlantic
Posted: 06/15/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Now you know why most shops charge 8 hrs.for a baseplate install.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
Nutinelse2do
On the Road Where the Weather Suits Our Clothes
Posted: 06/15/19 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! Sorry to hear of all your troubles.
Installation on our 08 GV was a piece of cake. Strange a couple years would make that much of a difference.
It will be worth it after you’re done. It’s a killer little toad.
Good luck with the wiring. Let us know you survived the process :-)
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
D.E.Bishop
Eagle Rock, CA
Posted: 06/16/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I am well aware of the Suzies being great toweds, this is my third, we had both a 1995 and a 2006 at the same time. Sold the 2006 because of lack of storage and it was too nice for off-roading and we loved the lighter Sidekick. That is up until it died.
People are amazed to see us in some of the places we go to just look around. The only problem I ever had was we were showing the DGKs some wild horses and some giggle bushes got caught in the cross member of the frame against the converter. We put the fire out and suffered no damage what so ever.
I'm trying RM's new easy connect diodes this time. I just want to test them out for the rest of you. Besides they are cheaper than the individual diodes or the one in two out diodes.
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 06/16/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Experienced the same thing putting a base plate on our 2005 GV. It took myself and a professional mechanic about 4 hours to do the installation. I'm not sure how one person could do it by themselves as we needed 4 hands to hold the brackets in place while the other installed the bolts. It was a very tight fit and we had to use a crow bar a couple of times to leverage the brackets to line up with the factory frame holes.
We agree, they make a great towed vehicle.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
