RV.Net Open Roads Forum: Class A Motorhomes: Frods V10 engine
 > Frods V10 engine
Big Katuna
Deland, FL
Posted: 06/16/19 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure of your budget but after 2016 you get a six speed auto that basically drops cruising rpm 1000 rpm.
Class Cs don’t get the three valve.
I’ve seen delivery vans in the NE go to auction with 300-400k miles. Not as heavily loaded as a RV but still ...
My Kharma ran over my Dogma.
T18skyguy
Eugene, OR
Posted: 06/16/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have two V10's and the maintenance is much easier than the old 460. The water pump is a simple 4 bolt unit with a big O ring just plug it in and your done. The V10's are strong runners and revvers and both of mine are rock solid. As stated above if you can afford at least a 2017 model motorhome(that would be a 2016 chassis) you get the 6 speed transmission which is also very good. As far as the spark plug issue's, just shop 2004 and later motorhomes.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
Big Katuna
Deland, FL
Posted: 06/16/19 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve seen several 16 models with the six speed. Look at the shifter for a D with a four next to it.
RedRollingRoadblock
Oregon
Posted: 06/16/19 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Passes everything but a fuel station.
dodge guy
Bartlett IL
Posted: 06/16/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
So 7-8mpg is bad. If I recall a DP of the same size may only get 1mpg better. So “passes everything but a gas station” is a useless statement.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
DFord
Near St Louis, MO
Posted: 06/16/19 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot to mention the 2006 F53 chassis for class A MHs (which began production on Jan 1st, 2005) included the 3 valve heads - that's where much of the added HP came from. Ford also streamlined the exhaust system with what looks like cast iron headers.
The more gears the transmission has the better. My 2004 with the older 4 speed transmission has trouble going up long upgrades. In the higher gear, it loses speed until it drops below 50 when it downshifts even lower and then starts picking up speed. A little over 50-52 mph, it upshifts (at about 4500 rpm) and starts losing speed again. If it had more gears, it would be able to at least maintain 50 mph or better.
Ford Introduces New F-53 V8 Engine, Transmission (3/5/2019)
From what's been said here, 2016 was another major upgrade year where 6 speed transmissions became standard.
Stay tuned for the 2020 F53 chassis (which I believe is now in production) for another major upgrade. The engine switches to a bigger V8 (the V-10 is on 415 ci) and a 10 speed transmission.
Oh,iIf I could on jack up my unit and put one of those under it! I have no inclination to buy a new MH.
Don Ford
'09 HHR 2LT Towed - BX1648 Baseplate
map40
Posted: 06/17/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
I have a rental fleet, all V10s. Most of them over 100K. One over 300K. Some close to 200K. Never an issue.
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
FloridaRosebud
Melbourne
Posted: 06/17/19 10:21am Link  |  Quote  |  Print  |  Notify Moderator
This is a very good datapoint. Thanks!!
Al
GHOST1750
THE GOLDEN STATE My taxes help keep it that way!!
Posted: 06/17/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
On my second V-10. First one was in 2001 Natioinal, no problems. My second on is in a Newmar Canyon Star 3953. The motor is fine my problem is the sound. I had a 350 CAT in between in a 2003 National Tradewinds with Sparton chasses. That will spoil you. Got rid of the diesel because of maintenence expense.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
 > Frods V10 engine
