RV.Net Open Roads Forum: Fifth-Wheels: brakes
 > brakes
gdweb
Posted: 06/16/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
what would cause my trailer brakes to not work when depressing brake pedal. but work fine with the integrated controller? 2013 F250 6.7 checked fuses and they appear ok.
Semper Fi
Gary & Diane
Ringor, Blueheeler/Bordercollie mix
2013 F250 6.7l FX4
2013 Sundance 3270res
pcm1959
home
Posted: 06/16/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Do you mean while parked or not moving? I don't know about Ford but on GM trucks movement has to be detected for the trailer brakes to be activated by the brake pedal.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
Lantley
Ellicott City, Maryland
Posted: 06/16/19 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
My thought as well were you actually rolling when testing?
You also need to be moving a minimum speed not just 5 MPH
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
MFL
Midwest
Posted: 06/16/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Your Ford IBC has little brake pedal effect below 20 mph. I often use the manual lever to assist my low speed stop. Also, if you are used to using an after market controller, that has an obvious early brake feel, the integrated is less noticeable.
Jerry
gdweb
Posted: 06/16/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
never knew that. will try it out tomorrow. thanks
Lynnmor
Red Lion
Posted: 06/17/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Funny the things that you can learn in the owners manual:
The trailer brake controller is equipped with a feature that reduces output at vehicle speeds below 11 mph (18 km/h) so trailer and vehicle braking is not jerky or harsh. This feature is only available when applying the brakes using your vehicle’s brake pedal, not the controller.
 > brakes
