RV.Net Open Roads Forum: General RVing Issues: Hot water
 > Hot water
machunt
cincinnati ohio
Posted: 06/16/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Gotta ask. when everyone id using there RV, how many have really clody, milky hot water? if so what have you done to remedy this?
Flute Man
Payson, Arizona
Posted: 06/16/19 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Never.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Jrparr32@gmail.com
602-321-8141
Full-timer
midnightsadie
ohio
Posted: 06/16/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like your tank needs a good flushing out. most likely lime deposits built up in the tank.
machunt
cincinnati ohio
Posted: 06/16/19 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
how do flush your hot water tank
westernrvparkowner
montana
Posted: 06/16/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
It is most likely very fine air bubbles. Fill a glass and let it settle. If it is clear and there is no sediment you have nothing to worry about.
BarneyS
S.E. Lower Michigan
Posted: 06/16/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me exactly like anti freeze in the water heater tank. It takes forever to get that stuff out if you don't change the winterizing valves correctly when either winterizing or de-winterizing. It doesn't take much either, to make the water foamy for a long time.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
cavie
Posted: 06/16/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
If a suburban pull the anode rod. If an attwood open the pressure relieve valve and let the water run a while.
MrWizard
Traveling
Posted: 06/16/19 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
i've seen that on one RV a friend had
something to do with the water where he lived
setting in the heater in storage
its been ten years and i don't remember the explanation
whether it was chemical or bacterial, seem to think it was something to do with sulfur content, i do remember it smelled that way
Radiate The Happy
1997 F53 Bounder 36s
aftermath
Washington State
Posted: 06/16/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
This. Happened to me once because of my error. Took a long time to clean out the HW tank.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
navigator2346
texas
Posted: 06/16/19 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
uTube is your friend
https://www.youtube.com/results?search_query=how+to+flush+an+rv+hot+water+tank
 > Hot water
