RV.Net Open Roads Forum: Travel Trailers: Another hot water heater question
 > Another hot water heater question
Npdchief07
Hamilton, Oh
Posted: 06/17/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
My travel trailer has a gas only hot water heater. Would this be (I don't know if I am wording this correctly) connected to a circuit breaker or a fuse?
Chris Bryant
Arden, North Carolina
Posted: 06/17/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
If it’s electronic ignition, it will be hooked to 12v power and be fused. Pilot type use no power.
-- Chris Bryant
Old-Biscuit
Verde Valley
Posted: 06/17/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
6 gal DSI
Weldon
Posted: 06/17/19 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
most likely 15 amp
Boon Docker
Posted: 06/17/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
A propane only water heater would not have a 15 amp fuse or breaker.
If it is a "self ignite" type heater it would draw less than 1 amp and would be fused. If it is a "pilot light" type heater it would not have a fuse or breaker.
Weldon
Posted: 06/29/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Recently my A/C would not come on, my water pump would not come on, the hot water switch for gas would not work and the switch used to open and close the slide outs would not work. After checking the problem, I replaced a 15 amp fuse and it corrected all of the problems.
ktmrfs
Portland, Oregon
Posted: 06/29/19 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
thermostat needs 12VDC, hot water heater with DSI needs 12V DC, fridge needs 12VDC even when running on 120VAC for the element,
usually fused by 10A or 15A fuse in the fusebox.
Often the slides are on a 30A 12V self resetting circuit breaker. I replace those with a 30A manual reset circuit breaker so they won't cycle on and off in the case of a real fault.
2011 Keystone Outback 295RE
GrandpaKip
Flat Rock
Posted: 06/30/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
If there is a switch inside the camper to turn it on, yes, it has a fuse.
If you have to go outside to light it, no fuse.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
CavemanCharlie
Storden,MN
Posted: 07/01/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yup,
opnspaces
San Diego Ca
Posted: 07/01/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
If the switch never lights up it sounds like a blown fuse or a bad switch.
With the switch off you should have 12 volts on one side of the switch to ground. If the switch is on you should get the same voltage on both sides of the switch to ground.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
