RV.Net Open Roads Forum: Truck Campers: Front tire pressure?
 > Front tire pressure?
Ramblin' Ralph
Central California Coast
Posted: 06/17/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Rig: 2006 GMC 2500HD with 2001 Lance 845 camper. Tires are Michelin LT265/75R16.
My door jam plate says:
Front 53 psi
Rear 80 psi
I have been airing up to:
Front 60 psi
Rear 80 psi
My axle weights with camper and loaded for long term travel are:
Front 3350 lb
Rear 5800 lb
That's just under my GVWR of 9200 lb.
Last summer I had my tires rotated when traveling and the shop said I had wear on the front (cupping IIRC) indicating not enough pressure. So they boosted the front to 70 psi (or more).
I'm getting ready to hit the road again for several months. What is the consensus on proper front tire pressure?
Thanks,
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 125 watt solar
My RV Travels Webpage / Yearly Campsite Map / 715 Campsites / YouTube Videos /
Instagram / Twitter
sbryan@vtbryans.com
Vermont
Posted: 06/17/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
My F350 says for a fully loaded truck 65 front and 80 rear. It has worked well for me for the last 35,000 miles with the camper on board. Tires rotated every 5K with essentially similar wear.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
d3500ram
Colorado
Posted: 06/17/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
The truck's placard should have tire PSI recommendations for loaded and unloaded conditions.
When I was fully loaded, I set the front to the truck mfgr laden recommendations while the rear was at the tire maximum. Under no conditions should the tire mfgr PSI be exceeded.
If your tires are "cupping" then it is generally due to bad shock absorbers.
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
TC-less, previous owner of 2 NorthStar pop-ups and 2 Northstar Arrows.
Monterey, CA
Posted: 06/17/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
“Tires rotated every 5K with essentially similar wear.“
That’s the key you are doing right, sbryan, IMO.
BradW
Mayor of Flat Rock
Posted: 06/17/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Consensus on the TC Forum? [emoticon] [emoticon] [emoticon]
When we hauled our Lance on our SRW trucks, I had less sway when we ran the front tires at 80 psi. Tires are part of the suspension and when the rear rocks side to side, the front does also. So anything you do to stiffen the front suspension helps, even though 90% of the added load is on the rear tires.
bradw
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
MORSNOW
Eagle River, AK
Posted: 06/17/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
I honestly never thought about the front tire pressure and sway before due to almost all of the weight is added to the rear. Hmmm
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
Posted: 06/17/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
60psi should be plenty of pressure for your setup. Check a load inflation chart but probably good for at least 2500lbs per tire
Many causes of cupping, feathering of tire tread and not all of them indicate anything is wrong.
Infrequent rotation
Curvy roads
Too low of pressure, maybe for the sway with a camper or in general
Bad shocks
Bad ball joints
Too much too little camber
Bad alignment
Not tailoring the rotation to how the tires are wearing.
If the truck is in good alignment and good condition then it could be just wear.
S Davis
Western WA
Posted: 06/17/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
You have your axle weights why not go with the inflation table for your tires?
jadatis
Holland
Posted: 06/18/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Filled in in my made motorhome-calculator, it comes to F 41 psi , R 75 psi.
Googled your sise tire to be loadindex 123 for single load is maxload 3420 lbs, E- load AT 80 psi.
Front that low??!! Yes , search the GAWR's, and you probably discover that rear is already overloaded, and front still have a comfortable reserve.
The vehicle-maker calculates for GAWR's ,and for that it probably needs 60 psi.
Are these the original sises and loadrange ( E- load / LRE AT 80 PSI) . If the weights are right, and tirespecifications I found too, especially the low front gives better comfort and gripp, but you yust gotten used to the kidney-belt[emoticon]
My calculator adds 10 % to the given loads( so yoy weighed ? !), and then calculates the pressure with a formula that gives higher pressure then the official European, wich America uses too but only for P-tires since 2006.
So my calculation is certainly not to low.
Determining the real weights is the most tricky part, in this all, but you weighed fully loaded, so also all the persons? , wich gives you already bonuspoints.
towpro
Compass PA
Posted: 06/18/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
here is the formula.
(A/B)x80=PSI
A is true weight on Each tire
B is max load on tire (marked on sidewall)
C is max PSI (marked on sidewall)
Hear is your rear calculation.
(2900/3472) x 80 = 66.82 so I would run 70
/ means divide by
But what your saying your front weighs appears to be a little low to me, or maybe its just me from years of driving Cummins.
* This post was edited 06/18/19 07:18am by towpro *
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
