RV.Net Open Roads Forum: Travel Trailers: Tow Vehicle
 > Tow Vehicle
pdxcamper
Beaverton, OR
Posted: 06/18/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I am close to purchasing a 2020 Keystone Cougar bunk house (29BHSWE) and will be pulling it with a 2018 Ford Expedition Limited Max. Tow capacity of 9000lbs. Weight of trailer is 6,810 dry and GVWR 8800.
Has tow package and class IV hitch.
Thoughts? For my TV no other options as I have 4 kids. Appreciate feedback.
West & above Bishop, California
Posted: 06/18/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Within towing specifications but toooooo close for me. What is the TV’s payload?
camperfamily
New Jersey
Posted: 06/18/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you'll be at or over your limits. 6 humans, plus gear, hitch. You'll likely be around 8500# ready to camp on the trailer. Do your math and remember kids have a funny way of growing,
As far as "no other TV options" we camped with a family of 6. They pulled with a CC picked with front bench. They even crossed the country that way so it can be done. A properly optioned 3/4 ton gas pickup would offer both more towing capacity, more payload and a longer wheelbase. All those thing will make for a better towing (safer) experience. Not what your original question was but sharing another family's experience that is the same size as yours.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
trailer_newbe
Tucson
Posted: 06/18/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Usually the cargo carrying capacity of the tow vehicle is the killer. My Tundra was well within the CVW of the trailer, but with only 1,387 in cargo capacity, the truck I was alway a few hundred over every time we towed.
2018 Jayco White Hawk 28RL
Rustycamperpants
Sugar Grove, Il.
Posted: 06/18/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
You're going to be over your capactiy some. Be sure you pack lightly, especially no water in the tanks. Your camper is 800# more than mine and I know I would not want to go with a bigger TT.
2009 Ford Expedition EB, 3.73, Equal-i-zer
2015 KZ Sportsman Showstopper 301BH
Posted: 06/18/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
And no water in the tanks means passing up beautiful camping opportunities.
twodownzero
NM
Posted: 06/18/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you're in the market for a 3/4 ton Suburban.
trailer_newbe
Tucson
Posted: 06/18/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
It is simply not a good idea to be over, but tow with what you have and see how it goes. Once you’re in the wind, or a semi passing you, you’ll know. Once you have to go through a mountain pass with steep upgrades and downgrades your mind will be made up. Your not so far over it’s dangerous as long as you give yourself some room and time. For me it took several thousand miles of varied terrain and I knew.
afidel
Cleveland
Posted: 06/18/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
The Expedition Max has pretty good capacity, even the nicely optioned one I saw at the auto show had 1700+ pounds, but that's probably not enough for a family of 6 and such a heavy trailer. Over 7k pounds is either max half ton or 3/4 ton territory when you run the numbers. Trailer at 8k pounds and 13% tongue weight is 1,100 pounds after you add weight distribution, 4 kids at 80 pounds each is 320 which leaves <300 for Dad, Mom, and everything else in the tow. The other problem is going to be rear axle capacity, with 1,100 on the receiver and a full passenger compartment you'll probably be well over but it's hard to know without actually doing a CAT scale.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
APT
SE Michigan
Posted: 06/18/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
That will be abut 8k loaded for a long weekend with 1000-1100 pounds of TW. Verify your receiver limit supports that. Add weight of your family to TW and verify your Expy has enough payload per driver's door Tire and Loading sticker.
2017 Subaru Outback 3.6R
 > Tow Vehicle
