RV.Net Open Roads Forum: General RVing Issues: Thermostat settings
 > Thermostat settings
wgriswold
Lake Tahoe
Posted: 06/18/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
My thermostat has three settings for the AC; low, high and auto. I think that low and high refer to fan speed and the compressor works the same in both settings. There is not much difference in fan speed between low and high. But what is auto? The manuals for the thermostat and AC do not say.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
rk911
Wheaton IL
Posted: 06/18/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
in our MH the fan continues to run after the desired temp has been reached. when using "auto" both the fan snd compressor turn off when the desired temp is reached.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
DrewE
Vermont
Posted: 06/18/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Auto generally means the fan turns off when the thermostat no longer calls for cooling. Manual or On means the fan runs continually, handy if you just want air circulation and/or lots of background noise without cooling. Typically the High and Low speed settings are independent options from the Auto and On/Manual settings, for a total of four possible permutations.
MFL
Midwest
Posted: 06/18/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, with the fan on auto, both fan and compressor will operate on/off as needed. With the fan setting on high/low the AC fan will come on with the furnace. If fan set to auto, only the furnace fan will run.
Jerry
Chris Bryant
Arden, North Carolina
Posted: 06/19/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Some models will also switch between high and low blower speed, as well as shut off when satisfied.
-- Chris Bryant
jarata1
Massachusetts
Posted: 06/19/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
not sure all do that usually you reach temp fan doesnt stay on
stickdog
Somewhere, USA
Posted: 06/19/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Our Dometic has high, medium, low and auto. Only time the fan stops is when the desired temp is reached on auto. We run both the AC units on high till night then place them on auto. We're in the mountains and the temps will drop below the set AC temp at night.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
wgriswold
Lake Tahoe
Posted: 06/19/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies. I will experiment some more next time I am at the trailer.
