RV.Net Open Roads Forum: Class A Motorhomes: A crappy experience
 > A crappy experience
Timothy2001
Full Timing for Now
Posted: 06/19/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Mike I know the fitting, on mine it’s new thank goodness,
2008 Itasca Meridian 39z
two travelers
Smithtown, NY
Posted: 06/19/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I once had an problem where the rubber "keeper" strap for the cover got caught in the connection to the hose so it did not seal properly. OMG what a mess to clean up when all I wanted was to sit with a beer after a long drive.
mr3117r
nampa
Posted: 06/19/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
I once had that happen to me. The rubber o-ring had come off the inside of the sewage hose connector. Leaked all over.
2006 dodge 3500 srw 5.9 cummins
1995 Winnebago Vectra
16ft hewescraft river runner
1956 chevy bel air
DFord
Near St Louis, MO
Posted: 06/19/19 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the "O-Ring" and make sure it's there and seated properly.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Wherever I happen to park
Posted: 06/20/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Take a look at the female connection (The one on the hose) there is SUPPOSED to be a rubber O-Ring in a Track" around the inside edge.. Im guessing not there.
Just a guess though.
Home is where I park it.
MetalGator
Posted: 06/20/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
As others have said, check the rubber O ring. My hose had always worked fine and one time it leaked bad when I was dumping. The black rubber O ring was missing. I picked up a 3 pack of them at Walmart and that fixed the leaking problem.
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
Cocky_Camper
Rock Hill, SC
Posted: 06/20/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Was there an o-ring on the end of it?
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
tiffy2000
NH
Posted: 06/20/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
The first time I used mine the fitting came right off the hose just after I dumped , thankfully it didn't in the middle of the dump. I also lost the step adapter the last time I dumped as the dump hole was a lot larger than the adapter and it caught on the edge when I pulled it out and dropped down into the dump hole, goodbye adapter ...wasn't about to try and fish it out.
Janss
Sedona, AZ
Posted: 06/20/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I've read about someone who bought a new Rhino that was missing the rubber o-ring.
I have what may seem like an odd experience. My Rhino leaked sometimes. I finally figured out that the extra little bit of the end of the hose material that stuck up inside the locking ring area was causing the leak. When I clamp the hose onto the motorhome pipe, if I would position the hose such that that bit was at the back/bottom, it would leak. But when I position the hose for that bit to be at the top/front, no leaking. This may just be an issue of the angles in my connection. But you might look into it.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
Timothy2001
Full Timing for Now
Posted: 06/20/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of the responses. I am shipping the old hose back and getting another in its place. Will fill the grey water tank with fresh water and test it out ensuring there is an o ring and it's in place. Man, I never want to go through that again.
