RV.Net Open Roads Forum: Turning your heat off at home while in Florida
Search only in Snowbirds
Open Roads Forum  >  Snowbirds
 > Turning your heat off at home while in Florida
napanee ted
Napanee Ontario
Posted: 06/19/19 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to know if its a good idea to turn your heat off and drain the water pipes while in Florida.Will this hurt the foundation and cause problems.
Thanks
midnightsadie
ohio
Posted: 06/19/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
in ohio we turn stat to 50deg and drain pipes ,you just never know about the weather. and have a friend check every week.
CarnationSailor
Carnation,WA
Posted: 06/19/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
In Seattle, X2.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
Kern County, CA
Posted: 06/19/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ask a neighbor that leaves during Winter. They will leave the heater on.
Flyboy320
Tappen, BC
Posted: 06/19/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Sent you a PM
rk911
Wheaton IL
Posted: 06/19/19 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
not off, down. we haven't drained water as we have a whole-house genny in case of a power failure.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Dutch_12078
Winters south, summers north
Posted: 06/19/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
We turn the heat down to 55℉ in our upstate NY cottage and turn off the water heaters and pump plus depressurize, not drain, the water system. We monitor the cottage temperature with an Acu-Rite system that alerts us by text message if the temp drops below our alert settings so we can notify family to check on it.
Dutch
2001 GBM Landau 34' Class A
MDKMDK
Canada
Posted: 06/19/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'm about 300 miles west of your 10-20.
We just turn the furnace thermostat down, and don't touch the water.
For thermal backup, I've got 2 X 30K BTU gas fireplaces, one up, one down, standing pilot, thermostatically controlled, set to fire up at just slightly lower than the furnace thermostat setting. If the power were to go out, the 2 fireplaces can heat the entire house, and keep the pipes warm. We hardly use our furnace in the winter at all any more, it's become the backup. We let the fireplaces handle the heating, and just keep it for summer cooling.
I can check the temperature via remote security camera access, if necessary.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
DFord
Near St Louis, MO
Posted: 06/19/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed a "Ring Spotlight Camera" over our garage door to compliment the "Ring Doorbell". I may add another Spotlight Camera for the backdoor/yard before we leave this winter. The Ring allows me to use my smartphone to see when anyone approaches our house and anytime I want to see what it's like back home.
I use an Ecobee thermostat on our heatpump to monitor the temperature inside the house. It alerts me when temperatures exceed my settings and when the auxiliary heat runs more than an hour in any 24 hour period. I can adjust the thermostat from my smartphone.
I don't drain the pipes but I do shut off the water as it enters the house and flush a toilet to relieve the pressure. I turn off the water heater and unplug as many power supplies as possible. Several lights are controlled by smart switches according my schedule to give the house a lived in look.
Cancelling the trash pickup saves us a bunch too. I submit a "Vacation Watch" to the local police and they check the doors on an irregular basis to make sure the place stays secured.
I contract (POA) with a lettercarrier out of our post office to collect my mail in my absence and forward it to me at the addresses I supply along our route. This has worked better than any method we've ever used including relying on relatives.
These measures allow me to enjoy our trips without worrying about the house or relying on others to stop by and check things (which never worked anyway).
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
almcc
Ontario, Canada
Posted: 06/20/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I set the thermostat at 10C and shut off the water. We have a smart thermostat and s service that I can log onto and look at the temps minute-by minute, it also is set to send me and our house checker an email if the temp goes below set point, it also warns loss of connection (for example power failure if power is off for longer than the battery backup lasts).
I don't want to go through the hassle of winterizing the water system if I shut off the furnace, don't like pink showers when we return!
