RV.Net Open Roads Forum: Class C Motorhomes: House batteries
 > House batteries
CaptR
Kanab, Utah
Posted: 06/20/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Hi all, my 2000 30' Fourwinds currently has 1 regular 12v battery- I see the pan is designed for a 2 battery setup. I happen to have two 6v deep cell Crown golf cart type batteries that will parallel to 12v. This would provide some serious power... would there be a concern of too much amperage for stock wiring/systems of this old rental rig?
Thanks in advance for the feedback. R
2oldman
New Mexico
Posted: 06/20/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
CaptR wrote:
.. two 6v deep cell Crown golf cart type batteries that will parallel to 12v. would there be a concern of too much amperage for stock wiring/systems of this old rental rig?
Series, not parallel. No, amps are pulled, not pushed.
Mono Basin National Forest Scenic Area
Posted: 06/20/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Follow a diagram to hookup the two sixes.
paynejr
Home
Posted: 06/20/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
As long as there is physical room to do the two 6v batteries (in series not parallel ) you should be ok. Have extra current capacity is always a good thing. Each circuit will only draw what it needs, the extra capacity will not force extra current into your unit. What it will do is allow you to go longer before you need to recharge
Retired and enjoying life
Sam Spade
North Central Florida
Posted: 06/20/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Not quite.
If devices could "pull" whatever they needed, you wouldn't need any voltage at all.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
BFL13
Victoria, BC
Posted: 06/20/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
A 2000 RV likely has a single voltage converter at about 13.8v. That will not recharge your 6s properly (or that single 12v, but replacing that is cheaper than two 6s.) but they will last a while.
Budget issue whether to replace them whenever, or make them last longer with a better converter/charger that will meet the battery charging specs.
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Chum lee
Albuquerque, NM
Posted: 06/20/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Considering the age of your RV, since it already has a larger battery box/pan, it probably initially came with 2 six volt batteries from the factory and someone later changed it to a single 12 volt to save money. So, it would be to your advantage to put the RV "BACK" to the way it came from the factory. (2-6 volt deep cycle batteries) I wouldn't call it "serious power" but, chances are, it will be better than what you currently have.
Chum lee
IAMICHABOD
Sunny So Cal 90713
Posted: 06/20/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Those Majestics,Former Rentals,all came with a single 12 Volt battery and a tray to match.
If yours has a larger tray it was modified if so that is a good thing.[emoticon]
A lot of Majestic owners on the Rental Thread would be interested in how you did it,many have asked on a way to put 2 6 volt golf cart batteries in that spot.
When you get it done please post pictures on how it was done and how it all worked out.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
bobndot
Posted: 06/20/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you have a 3 stage converter with some kind of charge wizard to monitor the charge rate. Look into a PD-4000 or PD-9000 series, they each worked flawlessly for me.
CaptR
Kanab, Utah
Posted: 06/20/19 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your input and corrections. Coach is in another state... probably will be a month before I get out there and see if the 6v series fits and compatibility of existing charger...
 > House batteries
