RV.Net Open Roads Forum: Tech Issues: Attaching solar to roof
 > Attaching solar to roof
suprz
rhode island
Posted: 06/21/19 08:01am Link  |  Quote  |  Print  |  Notify Moderator
"IF" you were going to put Solar panels on your RV's roof and you absolutely could NOT drill holes in your roof (TPO, EPDM etc) how would you attach the panels?
Proud father of a US Marine
twodownzero
NM
Posted: 06/21/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
If I couldn't attach my panels in a manner that involved screws, I wouldn't have solar on my roof at all. Once sealant was applied below, on, and above the screws, perhaps the screws could be removed and the panels wouldn't blow off, but there ain't no way in hell I'm relying on double stick tape or sealant alone to hold my panels on. I guess I could make some sort of metal contraption, screw it to the walls, and have it go over the top of the trailer, but there's no point when I can just dip a few screws in sealant and secure them properly.
2oldman
New Mexico
Posted: 06/21/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
As above, I wouldn't. The only possible solution is the tape, which is fastened to the rubber membrane. Not exactly a solid enough foundation for my peace of mind.
I don't know why you can't drill holes. There must be a hundred already.
opnspaces
San Diego Ca
Posted: 06/21/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Buy flexible panels and glue them down.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
dougrainer
Carrolton, Texas
Posted: 06/21/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Why can't you drill holes in the TPO/EPDM????????? Doug
BillyBob Jim
US
Posted: 06/21/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Flex Glue [emoticon]
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 06/21/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Most rigs have a luggage rail on the roof and you can put angles on the rails and hold at least 3 panels, did that with my first 2 panel's.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
West & above Bishop, California
Posted: 06/21/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
With a rubber roof glue can't be the only attacment. Screws are necessary. With Dicor, Eternabond and maintainance, what's the problem?
TomG2
Central Illinois
Posted: 06/21/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Buy long skinny panels that present the least frontal area to the air stream and HD Velcro. Did that for ten thousand miles in the last three years. Renew Velcro every two years.
RickLight
Washington
Posted: 06/21/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
as above; Flexable Panels and glue designed for both materials.
Adhesives are specifically designed for certain materials and are iffy at best for others. A good match is like welding, a bad match is like doing nothing.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
