RV.Net Open Roads Forum: Towing: Level trailer
Search only in Towing
Open Roads Forum  >  Towing
 > Level trailer
mosseater
Dillsburg, PA
Posted: 06/27/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Mine has been about 3/4" nose up for about 9 years and I have no issues. Just don't want to move and set up adjustments to get the 3/4" back. Tows fine, and you can't see it visually.
Sunset Creek 298 BH
Posted: 06/28/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
With a trailer that you can lift you observe that it is hard to lift the tongue off the ground, but when the tongue is way up in the air it is super easy to lift, and at some point (on single axle) you reach a teetering point (balance point) where the weight is perfectly balanced on the axle (half front, half rear).
The nose-down idea is to favor putting more weight forward vs putting it to the rear.
on tandem axle trailer nose down will put more weight on the front axles and will handle better then weight on the rear one.
This is almost entirely incorrect, as an extremely nose high trailer compared to and extremely nose low trailer "may" shift a very small amount of the tongue weight fore or aft by virtue of whatever weight is directly above the pivot point (axles) and the change in vertical component of that force (weight) by whatever angle it's at (couple degrees) from plumb or level.
Extreme being a couple/few degrees. Your example is with a single axle trailer that doesnt behave the same as a heavier tandem trailer. Like a tow behind air compressor or small gen set. They don't have a proportionate amount of tongue weight to begin with. They're fairly balanced and actually tow like **** because they dont have enough tongue weight to begin with thats why you can stand them on the back bumper when you pick up the tongue 30-40degrees.
If said tandem axle trailer is a torsion spring trailer, your last statement is incorrect due to the 2 axles not equalizing, in which case nose high and weight on the rear axle would make the front correspondingly heavier, not lighter as the pivot is now further rearward. And with the effective center of axle further rearward, apples to apples the trailer will be more stable and tow better because there's less tail waggin the dog.
* This post was edited 06/28/19 06:06pm by Grit dog *
Posted: 06/28/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
The real answer is, aside from axle weight concerns (if tandem torsion axles) or ground clearance issues or hitch height issues, nose up or nose down has very little to do with how a trailer tows. Period.
It's mostly aesthetics if you're not overloading an axle or dragging the tongue jack or back bumper.
ajriding
st clair
Posted: 06/29/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
This is definitely almost entirely incorrect!
myredracer
Langley B.C.
Posted: 06/29/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
This is what Ron Gratz (towing guru who used to post often here) posted a few years ago on this interesting thread.:
Yes, trailer nose down will move the CG slightly more forward.
But, the movement is so slight I doubt anyone would be able to detect an influence on towing stability.
Let's assume the distance from ball to axles' midpoint is 200".
Let's also assume the CG is 20" above TT's effective pivot point.
This means a 1" drop in the height of the ball coupler would cause the CG to move forward about 0.1".
With a ball to midpoint distance of 200" and a TW% of 15%, the "level" CG location would be about 30" forward of the axles' midpoint.
If you move the CG from 30" to 30.1" forward of midpoint, you change the TW% from 15% to 15.05%.
I think there would not be a noticeable effect on towing stability.
Personally, I found an improvement by having the nose slightly down compared to level. The most important thing about being slightly nose down has to do with braking. This is from another knowledgeable RV.net poster, also from a few years ago:
During panic braking the nose of the tow vehicle will dive because of weight transfer. When this happens the back of the tow vehicle and front of the trailer will raise up. This is not a good situation because the weight of the trailer will try to lift the back tires of the TV off of the ground. Braking with two tires is not a good thing and you want all tires of the TV braking equally. When the nose of the trailer is down like you have it; it will form a straight line when in panic braking mode; which is a good thing.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
Posted: 06/29/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
aj, if you don't believe me, go put a scale under the tongue jack on any normal tandem axle trailer. Measure tongue weight nose up and nose down as far as the Jack will go.
Then take the front wheels off and compare tongue weight and then take the rear wheels off (after reinstalling the fronts, to be clear) and check the tongue weight.
Once you verify what I said, come back and dispel your incorrect myth.
I'm not making this stuff up. Go take a Statics course and begin to understand moment arms and X-y-Z components of force and you'll see.
You can even do the same with your single axle example with very light tongue weight, save for the one axle vs the other thing. You'll find the same thing applies.
Thanks for playing.
mosseater
Dillsburg, PA
Posted: 07/09/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Or we could just hitch up and go camping. Just an idea.
gmw photos
midwest
Posted: 07/11/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
LOL, you guys are killin' me here....sent me out into the heat !
Tools to gather data: sherline TW gage, level, ruler.
Level, four inches high, and four inches low. And yes, I know, I placed the gauge under the jack which is slightly behind the ball. Get over it.
Tandem axle, leaf sprung, 19' funfinder.
Bedlam
PNW
Posted: 07/11/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Not the weights I experienced on my single axle flatbed: Based on your measurements, I would expect 4" low at 650 lbs, level at 600 lbs and 4" high at 525 lbs. I don't have a gauge for my dual axle enclosed (used bath scale on my smaller trailer).
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
gmw photos
midwest
Posted: 07/11/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I was never very good at science and math class, and I am sure not an engineer, but perhaps the "equalizer" device that sits between the axles of this funfinder trailer has something to do with it ?
 > Level trailer
