RV.Net Open Roads Forum: Folding Trailers: One very last water tank question
 > One very last water tank question
Npdchief07
Hamilton, Oh
Posted: 06/21/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Where would the fuse be for my hot water tank. It is a direct spark ignition. I have checked the box with the fuses all are marked but none mention hot water tank
West & above Bishop, California
Posted: 06/21/19 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Make, model, year of your folding trailer?
12th Man Fan
Flower Mound , Texas
Posted: 06/21/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
It would be listed as W/H or water heater and there should be a 120v breaker and a 12 v fuse. There are also some reset buttons on the heater itself. Might try resetting these.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Npdchief07
Hamilton, Oh
Posted: 06/21/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
It is a gas hot water heater, no electric
lenr
Indianapolis, IN
Posted: 06/21/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Those fuses are not famous for their labels. It's likely combined with something else. What is the issue? How about pulling the 15 or 20 amp fuses to see which one makes the light go off on the switch that turns on the water heater (if it has a lighted switch)?
Old-Biscuit
Verde Valley
Posted: 06/21/19 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
BRAND/Model would be helpful
PNW_Steve
Pacific Northwet & cold
Posted: 06/22/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
My propane refrigerators have all required 12 volts for the controller and ignitor.
I did borrow a 1970's vintage trailer once that had a pilot light and no electronics. Anything somewhat modern is going to require 12 volts.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
opnspaces
San Diego Ca
Posted: 06/22/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Can you get us the make and model? Guessing it's an Atwood here's a few things.
WATER HEATER LOCK OUT - GAS PRESENT BUT NO SPARK
High tension lead wire loose --- Secure wire connection on circuit board
Electrodes loosely attached to main burner --- Secure electrodes to main burner
Improper electrode gapping --- Re-position spark gap to 1/8? and into path of flame
Dirty electrodes --- Clean electrodes
Wires loose in electrode porcelain --- Replace electrodes
Cracked porcelain on electrode --- Replace electrodes
Defective circuit board --- Replace circuit board
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
kramer45011
Ohio
Posted: 06/23/19 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Suburban SW6D
opnspaces
San Diego Ca
Posted: 06/23/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
looking at the service manual at BryantRV (water heaters are at the bottom under miscellaneous) Link
It looks like there is a resettable circuit breaker on the side of the tank. you might see if the button is popped popped out. There is also a troubleshooting section near the bottom that you can run through with a digital volt meter if you have one. If you do not have a meter they are fairly cheap at Walmart or even Harbor Freight. We can also help you use the meter to perform any needed checks.
