RV.Net Open Roads Forum: Folding Trailers: One very last water tank question
 > One very last water tank question
Npdchief07
Hamilton, Oh
Posted: 06/24/19 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Thank you. Can you advise on what page you see info about the circuit breaker reset on side of tank?
opnspaces
San Diego Ca
Posted: 06/25/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
The diagram is on the right side of page 6 showing it connected with red wires. The picture is on page 18, unfortunately there is no picture of the actual location on the water heater. You might have to peel back some insulating foam on the side of the tank or remove an access panel to see the switch. Page 22 has a troubleshooting section that might help also.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Npdchief07
Hamilton, Oh
Posted: 06/25/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you
Old-Biscuit
Verde Valley
Posted: 06/27/19 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
Suburban SW6D.....
1) DC Voltage goes to on/off switch from a FUSED source (DC Dist Panel)
2) From switch it goes to a DC Junction box on left side of tank from the rear----wire nuts used to connect wires ---check if loose)
3) From the DC Junction Box the wiring goes to the set of t-stats --- High temp first then down connecting wire to Normal Temp
**(High temp trips if normal temp fails----manual reset via the PUSH TO RESET cover above gas valve---right side is for the propane Red Wires)
(Left side for 120VAC ---yours will only have the one on right side)
4) From the t-stats DC goes to circuit board ---backside of tank or attached to cabinet wall
5) DC then goes from circuit board to Gas Valve AND spark Electrode
Follow the DC to switch/from switch/from t-stat etc
