RV.Net Open Roads Forum: Travel Trailers: Forest River Wildwood 300BH question
 > Forest River Wildwood 300BH question
Chad/Jen
Posted: 06/21/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
We just got a new (to us) trailer, it's a Wildwood 300BH and it has two gray tanks. One empties with the black tank (more toward the front of the camper) and the other empties toward the back. This back one is the one I have a question about. It appears there are two pulls to empty it and I'm not sure what they connect to. The front tank is labeled black/gray for the pulls but these other two at the back aren't. I didn't know why there were two.
A second question is about the propane tanks/selector switch. The company we bought it from said to only have one tank on at a time because the selector switch doesn't really dictate which tank the propane is drawn from and if both tanks are open they'll be drawn from equally. This wasn't the case with our last camper.
Any help anyone can give on any of this is greatly appreciated.
Hearst San Simeon State Park
Posted: 06/21/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
The propane tanks will equalize if both are open at the same time. You want one to empty, then use the other tank. Refill empty tank when you can. Never want two empty tanks.
Winnebago 2101DS TT & 2019 Chevy Silverado 1500 LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - (MOS 1542 & 1560)
cavie
Posted: 06/22/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Not knowing your floor plan I'm going to guess. I'll use mine as an example.
rear dump on mine is one pull for black and one pull for gray. The front dump is one pull for Galley and one pull for Gray. Each tank has a seperate dump valve. No tank has 2 dump valves.
Not all tanks have automatic change over valves. If it is automatic The regulator handle points to the tank in service. Both tanks must be on but it will only draw for the tank at a time. Mine regulator has a valve with a pointer but is not automatic. I leave on off so I know when the in service one empty's. I then switch the valve to the other tank and remove the empty.
Regulator with a directional handle only draw from one tank at a time weather automatic or not.
WayneAt63044
St. Louis, MO
Posted: 06/22/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I cannot help with the dump valves question but suggest you Google the make and model of your propane switch to learn how it works.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
