RV.Net Open Roads Forum: Shopping for travel trailer. I need help, please
 > Shopping for travel trailer. I need help, please
Cheryl_B
Posted: 06/22/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
It's like pulling teeth to get these folks who are placing for sale ads to tell me the weights of their trailers. This particular guy I'm texting with now is giving me the "wt/wheels" weight which is 5,940.
Isn't that the weight that each axle can bear? That has nothing to do with the GVWR, right?
I'd just drive up and look at it but it's 2 hours north of me. Any help you can offer will be much appreciated.
Thank you.
1985 Class C Chevy Rockwood, 27'
Fulltiming since June, 2016. Flying solo but I'm never alone.
Fear not the unknown, but the fear itself.
Mojave, Kern County, California
Posted: 06/22/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
With the make, model and year lookup the manufacturer. That should give you the dry weight and the max weight. Add 1500 pounds for stuff, water, food, WDH etc. Most RVers don’t know or remember.
carringb
Corvallis, OR
Posted: 06/22/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
That weight sounds like the Gross Axle Rating for both axles, which in this case would be tire limited (probably 2 x 3500# axles).
Easiest thing is just ask to be texted a picture of the GVWR placard. If they can't supply that, I'd question whether they really have said trailer. Plenty of scams out there with pics lifted from real ads.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Cheryl_B
Posted: 06/22/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
He said that is the only weight that is on the title. I've asked him to send me a picture of either the GVWR on the title or to look for a spec label inside the trailer. This guy is driving me nuts, but this is so common with people selling trailers that are far away from me. I get aggravated!
Where is the most likely place those labels would be found in a travel trailer? My Class C has it in the closet near the bedroom.
wanderingaimlessly
SOBOVA
Posted: 06/22/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Cant guarantee it will be here but this site has a lot of info on used models.
rvusa
Good luck
Cheryl_B
Posted: 06/22/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. [emoticon]
KD4UPL
Swoope, VA
Posted: 06/22/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
There's no way the title weight is what you want, that could be anything. Every trailer has a GVWR plate. Most of them also have a yellow UVW sticker inside a kitchen cabinet. Tell your dealer if he can't send you the information from these too stickers then you will be moving on to a more competent dealer.
fitznj
nj
Posted: 06/23/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Every TT I have owned and 99% of the TTs I see have a yellow sticker on the
front left corner of the TT. Over the past few years I have seen another
sticker on the door which is a "as shipped weight".
I thought this was universal.
Gerry
okhmbldr
oklahoma city
Posted: 06/23/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
If it's a used trailer and you have the year, model, etc. you can go to NADA RV's, look up your trailer and it will give you the weight.
https://www.nadaguides.com/RVs
ppine
Northern Nevada
Posted: 06/23/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
You can look them up.
You can also figure out by looking at the construction and the size of the trailer what the approximate weight will be. Slideouts add around 400-500 pounds each.
aluminum frames with fiberglass are lighter than stick and tin.
