RV.Net Open Roads Forum: Tech Issues: Flowjet Waste Pump Blessing or Curse...?
 > Flowjet Waste Pump Blessing or Curse...?
IAMICHABOD
Sunny So Cal 90713
Posted: 06/22/19 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I may be gifted with a FlowJet and I wanted to get some input from Forum members that really own and use one, your thoughts on this one and really nothing else.
The reason for this gift? is that they say is a major PITA to use and setup and makes a lot of noise.
What do you all think? What is your experiences on using one.
If I use it there will be about a 15 ft run to a cleanout on my house that is 17 inches above the ground.
Thanks for any insight or helpful hints on the use on one of these.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
old guy
Oregon (pronounced Or e gun)
Posted: 06/22/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
don't wish to hijack your post but I have been looking at them too. I am interested in what the guys say about them also
ford truck guy
Pennsylvania
Posted: 06/22/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
I had one, used it a couple of times and the blades were always stuck...
I ended up gifting it to my BIL, and getting this - clicky
10 times better... Now, I only use it 2-3 times a year and I really like it
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
SoundGuy
S Ontario
Posted: 06/22/19 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't ever own a trailer with holding tanks and not have a FloJet waste macerator. No way I'm lining up at any campground dump station, I always have serviced my tanks once we're home, at my leisure. My FloJet stored in the front pass through so if the need ever came to off load black tank contents while we're still camping I've always had the means to do so. A series of pics starts here - click on the "i" at the top right of any pic for a text description.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
old guy
Posted: 06/22/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Good Grief at that price it should shine your shoes too
toedtoes
California
Posted: 06/22/19 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have the portable one. I love it. My clean out at home is positioned just right so I cannot use a stinky slinky practically. The flojet sends everything down the clean out quick and easy.
To set up, I attach it to the dump valve just like I would a stinky slinky, attach a dedicated garden hose to it (have the hose on a reel), then use jumper cables to attach to the house batery. Setup takes less than 3 minutes. Dumping takes about 5 minutes while just stand there, and it's about 3 minutes to clean and put away.
When I used the stinky slinky at home, it took a good hour having to "carry" the contents of the slinky out to the drain. Connections always leaked.
At dump stations, the stinky slinky works fine.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
time2roll
Posted: 06/22/19 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.rvweb.net/best-rv-macerator-pumps-reviewed/
I don't have one as the need has not presented for me. Seems like the biggest complaint is longevity and overheating. I recommend connecting with oversize 12v cable to minimize voltage drop. Too bad these portable macerators are not 120vac powered.
That is unless you want to go $600.
https://www.hodgesmarine.com/Jabsco-Macerator-Pump-115v-p/jab18690
675w Solar pictures back up
ford truck guy
Pennsylvania
Posted: 06/23/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Yea, I did not pay that , nor did I get it from them.... I paid just around $274.00 for it when I got it..... I need to find out exactly how much, cant seam to find the receipt.
SoundGuy
S Ontario
Posted: 06/23/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Bought my FloJet in 2006 so I could avoid dump station lineups, used it constantly since then, no issues at all, 'though I did finally buy a rebuild kit a couple of years ago because one of the rubber impeller vanes had broken off. 12 vdc is the only way to go as it means the ability to use the pump anywhere at any time, no need for a 120 vac power source. I'd also never buy any macerator that depends on a water source for operation - no need, the FloJet macerator is reliable, does what it's supposed to do, and will work just fine for years. Criticism always seems to come from those who've not owned one or have never used one. [emoticon]
Lynnmor
Red Lion
That is correct, but if you NEED one, then you do need it.
