RV.Net Open Roads Forum: Tow Vehicles: GM Colorado bent frame towing 2,100 lbs
Search only in Tow Vehicles
 > GM Colorado bent frame towing 2,100 lbs
Page of 7
ShinerBock
SATX
Posted: 06/22/19 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
From a Facebook post.
"A friend of mines Chevy Colorado with 10k miles was towing a 2100# camp trailer on a dirt road and hit a bump. This is the result. GM sent out an “investigator” 6 weeks later and has denied any warranty claims. They state the “the truck has 1” taller tires as the first reason. The second reason is the trailer is 2100 pounds, in the owners manual it states that trailers over 2k pound should have brakes. (Towing capacity listed as 5k) Since hit trailer is 100 pounds overweight and doesn’t have brakes that’s what the frame bent. No other damage to truck.
GM’s investigator took trailer to a certified CAT scale. Trailer is 2100lbs. Tongue weight is 347lbs.
Think twice about that Colorado purchase if you actually use your truck as a truck."
Click link to see pictures.
Facebook post
Edit:After doing a quick Google search of "Colorado bent frame", it appears that this guy is not alone with several people pasting about bent or cracked frames in the Colorado/Canyon forums at roughly the same spot.
* This post was edited 06/22/19 10:37pm by ShinerBock *
Huntindog
Phoenix AZ
Posted: 06/22/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I notice some fuel containers strapped to the trailer.. That can add a lot of weight. Were they full when this happened? When it was weighed?
I also see that the truck has a shell... More weight, and what was in the bed under that shell?
I doubt it was empty. Too much load for that truck.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
Ductape
On the Road
Posted: 06/22/19 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
"Hit a bump" translation: jumped the truck. Or worse.
Very little on Facebook is accurate.
49 States, 6 Provinces, 2 Territories...
pigman1
Delaware
Posted: 06/22/19 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Although I completely disagree with adjuster's reasoning for disapproving the claim, I do not believe that this problem is a GM issue. For that type of damage, I'd think your friend was hot dogging it along that dirt road and when he hit that "bump" the damage resulted. Way too fast for that dirt road. I owned a Colorado that had a cap on it. We pulled it to Alaska at least 4 times with overload springs and way over it's posted GVW without ever having a problem. Sorry, but if you must run outside a vehicle's limits, you need to make appropriate adjustments to your driving habits. I don't think this individual did that.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
ShinerBock
SATX
Posted: 06/22/19 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Lessmore
Canada
Posted: 06/22/19 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Not enough information, in my view, to make an informed decision.
ROBERTSUNRUS
Salem, Oregon
Posted: 06/23/19 12:23am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, my guess is that the driver hit a very hard bump causing the entire trailer to leave the ground; This put 2,100 lbs. directly on the hitch / receiver.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
newman fulltimer
louisiana
Posted: 06/23/19 03:32am Link  |  Quote  |  Print  |  Notify Moderator
Lippert now making gm frames ? [emoticon]
And has anybody noticed the extended hitch that would decrease load capability and put more leverage on the frame?
GordonThree
Northern Michigan
Posted: 06/23/19 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Sh*t happens, that's why you buy insurance.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
ib516
Canada
Posted: 06/23/19 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Lippert makes frames out of tin foil and welds them together with Elmer's glue. My 2010 Cougar 5th wheel frame failed when the RV was 1 year old. The pin box welds failed while traveling down the interstate and dropped the RV on the bed of my truck. JUNK!
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
Page of 7
