RV.Net Open Roads Forum: only 1 of my 4 tires is worn off on the inside
Search only in Towing
Open Roads Forum  >  Towing
 > only 1 of my 4 tires is worn off on the inside
83trekker
calgary,ab,canada
Posted: 06/23/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
i have my 99 27ft 5th wheel , went to go start repacking wheel bearings and noticed the right rear tire on the inside is totally worn off. Not sure when this started. Could a loose wheel bearing cause this? Seem a little loose when i was checking it.
Turtle n Peeps
California
Posted: 06/23/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it can. A lose bearing can camber the wheel.
I've seen junk tires do this also.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
83trekker
calgary,ab,canada
Posted: 06/23/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have maxxis tires and they have been amazing up to this point.
RCMAN46
NorthWest
Posted: 06/23/19 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem once with only one tire wearing.
This is what I found causing the excessive wear.
Several years ago while going from Flagstaff to Albuquerque I had an axle collapse. It was replaced by Lippert but it was due to some very bad chuck holes that I could not miss due to the size of the chuck holes a very heavy truck traffic.
83trekker
calgary,ab,canada
Posted: 06/25/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
When i get back out to my trailer i will look over the axle and shackles, thanks
time2roll
Posted: 06/25/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Take a close look at the tire to make sure it is very round and flat across the tread. MAXXIS are good but not perfect. I have had tread separation.
Also check the springs have a nice arch to them. Mine were flat and sagging bad enough at one point to throw the alignment off.
If you find absolutely nothing you can swap the tire to another position or get a new tire. If it repeats you are probably looking at a new axle.
675w Solar pictures back up
83trekker
calgary,ab,canada
Posted: 06/25/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanks will do, i have my 5th wheel at a storage place so next time i go out will look over everything like that too.
HuckleberryHunter
Issaquah, WA
Posted: 06/25/19 10:25am Link  |  Quote  |  Print  |  Notify Moderator
When I bought our first TT used (99 Layton) I noticed uneven tire wear on the back two tires. Despite repacking the wheel bearings the problem persisted, so when it was time to get new tires, I repacked the wheel bearings, got the tires installed, and then made an appointment at a frame/alignment shop to have the axels looked at. They adjusted camber and the such and those new tires rode true and wore even until I sold it many years later.
2019 Outdoors RV 21DBS
2016 Silverado 2500 Duramax
Equalizer 4-point WDH
myredracer
Langley B.C.
Posted: 06/27/19 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Definitely can. Inspect the bearings carefully to make sure they're all okay. Might be wise to replace them all. Use good ones like Timken if you do.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
mich800
Pontiac, MI
Posted: 06/27/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if I have seen that type of localized wear from a bearing. Typically it has been toe or camber that creates that type of wear. But I suppose the bearing could be so bad it is changing the alignment. I would think a bearing that loose would have destroyed itself by now.
