RV.Net Open Roads Forum: General RVing Issues: What type of insulation?
 > What type of insulation?
colliehauler
Mc Pherson KS USA
Posted: 06/23/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm putting a new roof on a RV project (wood and rubber). I need to put in insulation as well. It had 2 inch unfaced white spun insulation. The only thing the lumber yard has is 3.5 inch faced insulation. I think I have enough room for it but wonder if the faced insulation will be a issue.
What would you recomend?
Monterey, California
Posted: 06/23/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
What does the manufacturer of the faced insulation say about uses of its product?
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
pianotuna
Regina, SK, Canada
Posted: 06/23/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Think about how a vapor barrier is installed in a house.
Regards, Don
colliehauler
Mc Pherson KS USA
Posted: 06/23/19 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
That was the point of me asking. They use unfaced and I wondered about using faced and humidity build up in a closed roof, no attic to vent.
free radical
Canada
Posted: 06/23/19 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
If the roof was totaly sealed from inside,wouldnt that stop any humidity aka air
Moisture geting in?
I have plywood roof and glued on rigid foam everywhere from inside so no moisture can ever get onto the plywood.
This rigid foam is completely waterproof as its used for insulating basement walls on the outside,but also floats for house boats.
StirCrazy
Kamloops, BC, Canada
Posted: 06/23/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
2" foam would give you a much better R value than the stuff that was in there.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
colliehauler
Mc Pherson KS USA
Posted: 06/23/19 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
The problem is the roof is 6 inches in the middle to zero inches at the sides. I like the idea of foam especially since moisture should not effect it. Will probably use foam and maybe some regular insulation on the side of the roof.
pianotuna
Regina, SK, Canada
Posted: 06/24/19 12:56am Link  |  Quote  |  Print  |  Notify Moderator
I would use closed cell foam..
gbopp
The Keystone State
Posted: 06/24/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Another option is to use a Wide Application Tip.
You can use Great Stuff, or other, canned closed cell foam to cover the ceiling.
CFerguson
on the road
Posted: 06/24/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Maybe get a pro to install expanding spray foam. Advantage of completely waterproof if you do it right.
