RV.Net Open Roads Forum: Fifth-Wheels: Tripod stabilizer
 > Tripod stabilizer
amxpress
Clayton, NC
Posted: 06/24/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
When I use my tri-pod, I drop the front of the trailer down and load the tri-pod. It makes a different when moving around in front, a little when moving around in the rear of the trailer. If I adjust my Strongarms per the instructions and use my tripod, my trailer is very stable.
2012 Toyota Tacoma TRD Sport 4X4 long bed
2021 Airstream Bambi 22FB
Equal-i-zer hitch
Prodigy P2
Champion 3500 genny
M.I.L is self quatanting in Jacksonville Zoo
rhagfo
Portland, OR
Posted: 06/24/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
N-Trouble wrote:
Only ones that like em havent used a good chassis stabilizer like Steadyfast or JT Strongarm
This is the way to go! We have the JT's and they are great.
PPL MH JT Strongarms
JT Strongarms Amazon
JIMNLIN
Oklahoma
Posted: 06/25/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
The pin stabilizer will only stabilize side to side motion at the trailers front and does nothing for the rear.
Since '03 I've used a aluminum bipod pin stabilizer that stops side to side movement up there. For the rear I use BAL telescoping stabilizer which stops all movement back there.
I use adjustable chocks between the tires that eliminate fore and aft movement.
Or JTs or other brands types work just as good.
JAC1982
Brighton, CO
Posted: 06/25/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all! I'll look into those StrongArms, they look interesting. Of course the better option is the more expensive one [emoticon]
And yes, our rear stabilizer is just past the rear tires. The trailer still extends pretty far beyond there so it does make sense why it would move like it did when there's people back there. We don't often have people staying with us so that's good at least.
2020 Keystone Montana 294RL
2017 Ford F350 DRW King Ranch
kennethwooster
Perryton Tx USA
Posted: 06/25/19 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
We used one for 10years. Definitely helped. We had a 31 ft. cameo with the Big Foo I had t hyd. Stabilizers. Stabilizer helped. It only had 4 legs. Now we have a Beacon from Van Leigh. It has 6 legs. We don’t need the stabilizer any more
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Pipeman
Windsor, Ontario,
Posted: 06/26/19 04:45am Link  |  Quote  |  Print  |  Notify Moderator
Had one, still have it. It's a memento and has been in the shed for more than a decade. I installed the steadyfast system and they work very well on my 35 ft 5er.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
jdb7566
minnesota
Posted: 06/26/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a rubber bushed pin box such as a Mor-Ryde, a tripod isn't much help, a non-bushed pin box works well, at least that has been my experience.
Lexx
California
Posted: 07/08/19 02:22am Link  |  Quote  |  Print  |  Notify Moderator
We use a combination of Andersen Jack Blocks, Steadyfast Stabilizers, and a BAL kingpin tripod stabilizer. The trailer is now vastly more stabile.
The Jack Blocks allow us to level without extending the jack arms as much. This decreases the lever arm effect so there is less arm to deflect.
The Steadyfast is noticeable more so in the main room. While the rest of the trailer is much more stabile, I could still feel the rocking and rolling in the master bedroom.
The BAL kingpin tripod stabilizer has made a HUGE difference In stabilizing the master bedroom.
I suspect it is because of how much the master overhangs. The tripod stabilizer adds the sorely needed support.
We have triplet 8 yr old boys that run and jump. It no longer feels like we’re inside an old airplane in heavy turbulence.
2017 Ruby Red Platinum F450 - my kids call her "Big Red"
2018 Grand Design Reflection 28bh
FlatBroke
CO/AZ
Posted: 07/08/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Jump on the bandwagon, buy one, use one and sell one.
Hitch Hiker
"08" 29.5 FKTG LS
rhagfo
Portland, OR
Posted: 07/08/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Well spend your money wisely, tripods cost $125 to $150, and don’t work very well!
You can get JT Strongarms for about $225, well worth the extra $100!
PPL Morton Homes JT Strongarms
 > Tripod stabilizer
