RV.Net Open Roads Forum: Tech Issues: Charging battery with Honda 2000
 > Charging battery with Honda 2000
BlueBoy
Comfort, TX
Posted: 06/24/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Will my Honda 2000 charge the battery as fast on eco as it will fill throttle?
BlueBoy
Arctic Fox 29-5E (a.k.a. "Escape Pod")
F-350 6.0L PSD 4x4 SRW Crew Cab
TurnThePage
North ID
Posted: 06/24/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming you are plugging your RV power plug into the generator, and charging via the onboard converter (or inverter), it shouldn't matter if you're on eco or full throttle.
2015 Ram 1500
2004 Pioneer 18T6
Monterey, CA
Posted: 06/24/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
"Fast" charging during the bulk phase. The absorption phase is a different animal. Your batteries accept lower and lower amps. It's NOT what you offer but what the batteries will accept. Read some basic RV battery/electrical tutorials.
FLY 4 FUN
Alberta
Posted: 06/24/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Your onboard converter will "demand" as many amps as it needs to charge your batteries. Should you be on eco mode it may ramp up the Honda if the converter pulls a lot of amps initially. Once the battery begins to get a decent charge it will spool down again so no harm done.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
GordonThree
Northern Michigan
Posted: 06/24/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Better question is; how aggressive is my on board converter / charger?
Some folks put the gen in eco, and it putters along for 12+ hours because the on board converter never kicks into high gear.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 06/24/19 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
READ THE CHARGER'S MANUAL
Most everything I've read has the charger coming to a near screeching halt when the batteries arrive at 80% charged. Then to fill the remaining 20% it may take weeks or forever connected 24/7.
An absurdly perfect way to sulfate the battery to oblivion. Mixing the electrolyte to avoid stratification? Well, that would happen only if you got into an accident and your rig overturns.
99% of today's "battery chargers" are children's play toy "Tickle Me Elmo" frauds. Smart? A three-toed sloth would kick their ass.
The government ethic is to have you burn 400 gallons more of gasoline and buy three batteries instead of one to save .0001% on hydrogen and sulfur pollution. The same people who want to poison the entire Mississippi River drainage with fertilizer and deadly insecticides with corn growing pollution. Mexico flatly refuses to use food to cause environmental destruction.
Answer me this. SUGAR BEETS render twice as much alcohol using an eighth of the farmland area, a tenth of the pesticides and a truckload yields twice the alcohol. Ask your failed lawyer congressperson why this is...
time2roll
Posted: 06/24/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Using the 12v battery cord or are you plugging in the main RV cord to the generator?
12v needs eco off
120v eco does not matter
If you have a WFCO converter plugging in will be a trickle charge either way.
675w Solar pictures back up
DarkSkySeeker
Freestone, California
Posted: 06/24/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto - not sure about the sugar beets.
There is something special about camping in an RV.
KD4UPL
Swoope, VA
Posted: 06/24/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you are using the 12v charging output of the generator stop. It's weak and unregulated. Plug your AC charger into the generator. When it's charging hard it will pull the gen off of eco mode. When the batteries are nearing full it may go to idle. Letting it run wide open all the time won't help anything.
ktmrfs
Portland, Oregon
Posted: 06/24/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
but it will make more noise and use more gas.
Hint, if the batteries are discharged and the honda stays at low rpm when charger is on, you likely have a WFCO and aren't getting much charge at all and will take days (literally) to charge the battery. A PD60A charger will draw about 1000+VA (crummy power factor) and if it is charging the generator will NOT be idling, it will be running reasonably hard. The WFCO should do the same, but rarely does. it usually stays at 13.6V or around 15A, generator running at idle.
2011 Keystone Outback 295RE
