RV.Net Open Roads Forum: Class A Motorhomes: 50 to 30 to 15 amps
 > 50 to 30 to 15 amps
cavie
Posted: 06/25/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
OP is not asking about how to wire a receptical. OP stated he is moving and does not want to install one. OP simply asked if he could plug into a 15 amp circuit using a dogbone.
dodge guy
Bartlett IL
Posted: 06/25/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
It will work without a problem as long as you limit what you use. Although I would recommend installing at least a 30A RV outlet. At least then you can run everything (only 1 AC if you have 2)! That’s what I do and have no issues.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
AllegroD
Outdare
Posted: 06/25/19 11:20am Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
I have a 50A to 15A Dogbone. You don't need two reducers. This is what I use. Your setup might be different but I'm sure you can find the right reducer for your rig. Click Here
I prefer THIS ONE. I like the 90 degree on the 15 amp side.
Timothy2001
Texas and NY
Posted: 06/25/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I purchased the 50 to 30 in the event we come across a park where there is only 30 amp service available. Just ordered the 50 to 15 for the house.
Thanks for the input all!
2008 Itasca Meridian 39z
Chum lee
Albuquerque, NM
Posted: 06/25/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
You probably won't have a problem doing what you suggest.
"I realize I will need to limit the load to under 15 amps."
The problem is that "EVERYONE ELSE" other than you who uses the RV needs to be aware of the 15 amp limit too. If they aren't, then you have created the possibility of having your dog bone adapters/extension cord(s) functioning as your circuit breaker which they are not designed to do.
When we were kids, we burned up my moms vacuum cleaner because we didn't know the limitations. Some how we managed to insert a 120 volt plug into an outlet that was wired for 220 volts. (it's a long story but we did it) That vacuum worked really good . . . . . for a few seconds. That's when the smoke started pouring out of it. My mom wanted a new vacuum anyway.
Chum lee
sundancer268
Charlevoix
Posted: 06/26/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Just because it is a 15 amp receptacle doesn't mean it is limited to 15 amps. I have seen many 15 amp receptacles wired with #12 wire and feed from a 20 amp circuit breaker, I did that in my garage and barn and everything else I wire up personally. 15 amp receptacles use to be cheaper than 20 amp and I can change the receptacle if I need 20 amp at that spot.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
