RV.Net Open Roads Forum: Tech Issues: Change to Lithium-ion?
 > Change to Lithium-ion?
Page of 7
pianotuna
Regina, SK, Canada
Posted: 06/26/19 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
What is missing from most converters is temperature compensation. If you camp in extreme weather (-40 to +40) then it is needed at both extremes.
Neither the WFCO nor PD converters are "up to much", but at least the PD can be set to a higher voltage.
Regards, Don
steveh27
Grosse Pointe Woods, MI
Posted: 06/27/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
I am awaiting delivery of 200 ah of these batteries for my Class B. They come with BMS and mounting terminals.
https://www.amazon.com/3-2V100Ah-Lithiu........%2Brv%2Csporting%2C175&sr=8-1-spons&th=1
They said all my wiring and charging systems will work. I have a PD4635.
I only have room for 1 lead acid battery of 105ah. So I should have much more amps to use 80% of 200 = 160, vs 50% 0f 105= 52. They're supposed to charge faster and better so I will not be adding to my 120 watt portable solar panel. My only concern is Using it in the 1st week of December can be cold. This is their reply:
Our LiFePO4 battery working temperature is -20 to +60 Degree C for discharging, and 0 to 60 Degree C for charging, -10 to +45 Degree C for stock. And we have done testing at -20 Degree C, the result should make sure battery have 60% more capacity under this condition.
I hope my Trimetric meter will give good info on it's status.
I emailed with the factory to meet my small battery size for 200ah and they came up with a set. They had me buy through Alibaba (a first) for $1,400.
I spend at least 30 days snowbirding in FLA without hookups and some here in Michigan.
2oldman
New Mexico
Posted: 06/27/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Link doesn't work. Has a space in it.
2oldman
New Mexico
Posted: 06/27/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
The most Chinese looking battery I've ever seen.
* This post was edited 06/27/19 09:09am by 2oldman *
pianotuna
Regina, SK, Canada
Posted: 06/27/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
That's getting down to similar cost as an AGM.
RCMAN46
NorthWest
Posted: 06/27/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I have used LiFePO4 in radio control airplanes for the radio system batteries.
The LiFePO4 is very stable very little danger of fire if the battery is mistreated.
As said before a major drawback is the LiFePO4 has a very flat discharge voltage curve.Thus very difficult to determine if the battery is near its discharged state. They only way I know of is an accurate record of the volt amps used. There are instruments that can track the volt amps used.
Here is a device I use and has a 50 amp continuous rating. On draw back it has to be de-energized to reset the readings.
DC power meter
2oldman
New Mexico
Posted: 06/27/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure that's true of RV batteries. My 48v pack will show a voltage drop.
larkyblast
calgary
Posted: 06/27/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Those chinese batteries sure look interesting.
RCMAN46
NorthWest
Posted: 06/27/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
What batteries are used in your 48v pack. I mean manufacture and type or part number.
MrWizard
Traveling
Posted: 06/27/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
2oldman
How much of a voltage drop from full to 50% SOC
Then it would be 1/4 of that for a 12v drop in battery
Radiate The Happy
1997 F53 Bounder 36s
Page of 7
