RV.Net Open Roads Forum: Technology Corner: speakers to add to the tv
 > speakers to add to the tv
larry barnhart
wenatchee. wa usa
Posted: 06/27/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Would this be something I could add for more sound?
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Bill.Satellite
Full-timer
Posted: 06/27/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Would what be?
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Bill.Satellite
Full-timer
Posted: 06/27/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I added sound bar to my TV and it was an awesome decision. The TV had a digital audio out which would be required for most sound bars so what you have in your RV will make a big difference.
rk911
Wheaton IL
Posted: 06/27/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
a sound bar might be a better solution. they are designed to
mate with the flat screen digital tv’s.
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Beverley&Ken
Tottenham,Ontario
Posted: 06/27/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Most likely yes. If your TV has an audio output jack (either 3.5 headphone jack or RCA connections, then yes. Connect one of those to appropriate inputs on your sound system. My headphone jack is plugged into the dash radio and and then I use the rear speakers, which just happen to be close to the TV.
Some RCA jacks maybe labeled fixed audio , volume controlled by secondary amplifier or marked variable level, then volume could be controlled by the TV
Ken
Edit added Yes the sound bar would be the best option, connect to TV the same way, even a available with sub woofer
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
theoldwizard1
SE MI
Posted: 06/27/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Several years ago we bought a small (21'?) flat screen TV for the kitchen. The speaker were TERRIBLE. I picked up a pair of powered computer speakers (no woofer) for under $20. They work great !
Near USFS Glass Creek CG, Inyo County, CA
Posted: 06/27/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Provided you don’t dry camp/boondock or if you do dry camp factor in the amp draw in your battery selection and solar or generator charging, a good modification IMO.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL flagpole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
larry barnhart
wenatchee. wa usa
Posted: 06/27/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
thanks I will be looking at the items above.
chevman
DFord
Near St Louis, MO
Posted: 06/27/19 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
I found a nice set of powered computer speakers in a thrift store. They are head and shoulders better than the cheap built in speakers in the TV. I just plugged them into the headphone jack on the TV. I can still adjust the volume with the TV remote.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
RoyB
King George, VA
Posted: 06/28/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Larry - We added BLUETOOTH speakers for outside patio use... Bluetooth has a pretty good range for outside so no wires needed. AMAZON has a alot of good bluetooth speakers you can use outside. Also WALMART...
I'm always doing something outside close to the camp setup so a pocket bluetooth speakers is great for that... I can walk all around and still be in bluetooth range... I use those small ILUV bluetooth pocket speakers... They will run six hours or more on a USB charger... I don't know how they make these small speakers sound so good... These will also sync up to your cell phone as well... Lets me listen to Broadcastify.com radio scanner frequencies walking around...
google image
Roy Ken
