RV.Net Open Roads Forum: Travel Trailers: carbon Monoxide alarm going off
 > carbon Monoxide alarm going off
Snomas
Sedona, AZ
Posted: 06/28/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Our first trip w/ our new travel trailer (2 months old) the carbon monoxide alarm goes off when I run the hot water heater on gas. The alarm is located 6" off the floor on the opposite side of where the hot water heater is located. Why is gas coming inside a new trailer? The alarm is a dual alarm for both propane and carbon monoxide. Its obvious that the mfgr has a problem w/ the heater installation that allows CO2 to come inside the tlr.
I'm pis#$ off and just venting.
2019 Flagstaff micro lite 21DS
* This post was edited 06/28/19 06:47am by Snomas *
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
enblethen
Moses Lake, WA
Posted: 06/28/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Chemical odors in the new rig from items like the carpet.
Rig needs to get aired out good. Open vents, windows and put fan inside to circulate the air.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BillyBob Jim
US
Posted: 06/28/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
It would be next to impossible for CO to find its way inside the rig from the water heater. You would need to have a huge hole somewhere in the sidewall, a large gap around the water heater mounting flange itself, or some off the wall condition where its coming in through a window or vent. I would guess a defective alarm as the ones used by the OEMS are the cheapest obtainable.
You don't have a farting dog in the rig do you?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/28/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Check your batteries voltage when it goes off as it has three detectors...one for low voltage.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
HadEnough
Traveling. Always.
Posted: 06/28/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
We get water heater exhaust in the RV all the time since it's located directly below a window. We shut the window when using the propane feature of the water heater.
ford truck guy
Pennsylvania
Posted: 06/28/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
My dog farts a lot..! ! [emoticon]
BUT anyway, we HAD a trailer that the detector used to go off every time my wife used her hair spray..or cleaned with a certain cleaner
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
GrandpaKip
Flat Rock
Posted: 06/28/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Can you smell propane down by the floor?
If it is propane, I’d check every connection with soapy water in a spray bottle.
I check our detector every spring with a propane torch. Unlit, of course.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
ADK Camper
New york
Posted: 06/28/19 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
I once had my CO detector repeatedly alarm. I shutdown the propane at the tanks so there was no propane or co2 anywhere in the camper, but the alarm continued to go off. I finally figured out the problem - some ripe bananas my wife had put in one of the cupboards.
BillyBob Jim
US
Posted: 06/28/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you give him / her 4 or 5 slices of really good Swiss cheese it will put an end to that. At least on a temporary basis.
CFerguson
on the road
Posted: 06/28/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
CO detectors can and do go bad. Occasionally very early. I had one and the dealer replaced it under warranty. Someone once told me to replace them every 2 years fwiw.
Oh, and pineapple soaked in beer is best for dog farts.
