RV.Net Open Roads Forum: Truck Campers: Using tape on aluminum roof seal?
 > Using tape on aluminum roof seal?
BMW442
Western Mass
Posted: 06/28/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everybody
I know from past experience that many if not all campers eventually develop leaks
recently I picked up a nice older aluminum truck cap/canopy/shell to build out into a small camper. It's taller than cab height, with a sloping frontside, 2 big sliding windows, and a huge clear glass window. I insulated it with 1/2 inch foam, then screwed & glued 1/4 birch ply on the walls, with carpet-covered luan on the ceiling
just took it out for the maiden voyage up to the white mountains where it was POURING rain for a good 12 hours, like torrential, can barely see style. got in the camper that night & noticed water coming down the inside wall pretty steady
I'm thinking that it might be the one center seam on the roof of the shell. that's the only seam up there and it may have been tweaked slightly when I screwed the walls into the square tubing framing
am trying to figure out the best fix...have read about people using JB weld, dicor, silicone, and roofing tape. I am eyeballing the Gorilla Waterproof Patch and Seal Tape and also the Eternabond RV Tape. both are uv-rated and made specifically for mobile/roofing applications
does anyone have any experience with this type of fix?
any advice or suggestions is much appreciated!!
Kayteg1
California > Nevada
Posted: 06/28/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
All the tapes are not only tricky to apply, but look redneck.
Your aluminium plates should have sealer between them, so patching the leak on the surface will be ... patching.
Anyway, I tried lot of caulks and even the expensive marine grade don't hold on long term.
The best choices would be dicor in clear, or OSI QUAD Quad if you want color.
cewillis
Tucson, az, usa
Posted: 06/28/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Eternabond works great. Appearance is/can be questionable, depending on how visible it will be, what color it's going over, and how much you care about how it looks.
Cal
jaycocreek
Idaho
Posted: 06/28/19 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Snow Roof....I do all my aluminum roofs with it and have for years..Works great and reflex the sun also..
'94 Ford DRW/460-Lance 9.6
Army Basic Fort Benning Georgia
AIT-Fort Rucker Alabama-67A10
BMW442
Western Mass
Posted: 06/29/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tips!
It is only on the roof so it won't be visible to anybody but the birds & big rigs
if I go with tape it will be black to match the cap & truck
will look into those other products too, thanks guys!
mountainkowboy
Socal > NE Oregon
Posted: 06/29/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
My S&S has an aluminum roof and eternabond tape works great on it as long as you Dicor the edges.
Chuck & Ruth with 4-legged Molly
1990 F350 S/C Lariat Dually (Red)
1990 S&S 11SC Cabover
2011 Ford Ranger
1987 HD FLHTP
Tamnative
Mill Valley
Posted: 06/30/19 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
As the above recommendations are good and eternabond tape work great as I have it on my own camper,if the entire camper is aluminum you may want to try the aluminum type tape that they use for HVAC installs. It holds Very well and won't look to "Redneck" worth a try.
2005 Ford F-350 ex-cab Lariat 4x4 srw 6.0 Powerstroke
2008 Bigfoot 10.4
ticki2
NH
Posted: 07/01/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
You didn't say how the seam is made up . Does it go front to back or side to side ? Does it overlap or butt with molding ? Adhered together , screwed or riveted . Are there any other protrusions through the roof . If water is coming down the wall it could also be the seam where the roof meets the wall .
'68 Avion C-11
'02 GMC DRW D/A flatbed
joerg68
St. Ingbert, Germany
Posted: 07/01/19 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Any single hole can leak. So can window frames, roof hatches, mounting holes of roof racks ... anything. You do not need a big hole, just water on the outside and gravity.
If it is an older aluminum roof, it could also be corrosion pinholes. Barely visible from the outside.
With your description, it is hard to tell whether there are other potential candidates. A picture or two would help.
sonuvabug
Mid-West Ontario, Canada
Posted: 07/07/19 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I used 3M's Extreme Sealing tape to seal around the edges, roof fixtures and front seam on our older Class C. This is the same tape they use on the 300+ kph bullet trains in Europe. It isn't cheap but it sure does what it is designed to do. Pretty easy to install and once it is down, it is down for good. I'd hate to be the guy to remove it.
2007 Adventurer 90fws Truck Camper
2001 FORD F250 SuperCab; 8' box; 4x4, 7.3l diesel, rear Sumo Springs
