RV.Net Open Roads Forum: Fifth-Wheels: Leaky waterhose
 > Leaky waterhose
Frank55
Posted: 06/28/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I keep having a waterleak on the hose coming into the trailer. I have put a new washer, used teflon tape and have tightened it up as much as I can an it still leaks! Any suggestions.
mtofell1
Oregon
Posted: 06/28/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Probably need to cut off the end and replace it with a new one (or just get a new hose). For whatever reason these RV hoses sure do seem to leak often and after a short amount of time. It seems like every time I go out I've having to change one end or the other.
fj12ryder
Platte City, MO
Posted: 06/28/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Teflon tape won't do any good because the rubber gasket is the sealing area. Time for a new hose.
Howard and Peggy
"Don't Panic"
newman fulltimer
louisiana
Posted: 06/28/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Cheap hose end and bends easy or flex get a better hose or hose end
Rover_Bill
NE. Ohio
Posted: 06/28/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure the city water runs through the water pressure regulator BEFORE it goes through the hose. High city water pressure will make the gaskets leak.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
edatlanta
Maplesville, AL - Home Base
Posted: 06/29/19 03:24am Link  |  Quote  |  Print  |  Notify Moderator
Get 100% rubber gaskets not the cheapie type that come on a punched out card with a bunch of them that you have to tear off. The big box home stores have them. They last and seal much better than the cheapies.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Vvvv1010
San Antonio, Texas
Posted: 06/29/19 03:26am Link  |  Quote  |  Print  |  Notify Moderator
Try replacing the “city water inlet” on your RV. The threads on the inlet become soft and the fresh water hose doesn’t firmly seal causing it to spray or leak. Usually, 3 screws gently pull and replace.
2011 Jayco Jay Flight G2 32BHDS
2011 Ford F250 6.7L Turbo Diesel
Two 10'0 Kayaks
SailingOn
Central Texas
Posted: 06/29/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Banjo fittings, one on the trailer and one on the hose, make a solid leakproof connection, and don't corrode. I think they're lots easier to connect/disconnect than the standard hose ends. First picture is the hose end, second the trailer end.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
AD5GR
bpounds
Sophmore Brain...
Posted: 06/30/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Some water hoses have paper thin formed ends. Better hoses have ends machined out of thick brass. Which do you think will leak? Choose wisely.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
fj12ryder
Platte City, MO
Posted: 06/30/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
But doesn't that just transfer the drips/leaks to where the Banjo fitting is attached to the hose?
 > Leaky waterhose
