RV.Net Open Roads Forum: Fifth-Wheels: Leaky waterhose
 > Leaky waterhose
SailingOn
Central Texas
Posted: 07/02/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
But doesn't that just transfer the drips/leaks to where the Banjo fitting is attached to the hose?
Sure it does.
But the Banjo pair takes the stress of repeated connect/disconnect cycles, with less strain on the trailer fitting or the hose.
So perhaps the hose, and more importantly the trailer fitting, will last longer.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
AD5GR
rhagfo
Portland, OR
Posted: 07/02/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Quality hose, while the current white hose is still sealing fine, when it starts getting leaky it will be replaced with a ZeroG hose.
laknox
Arizona
Posted: 07/02/19 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 90 degree connector to eliminate stress on the hose and fittings. Just sayin'...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
fj12ryder
Platte City, MO
Posted: 07/03/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I got one of those too, and it seems to work like it should although the first one I bought leaked. The second one is leak free. And it would definitely ease the strain if the hose is hanging straight down instead of sticking out and down.
Howard and Peggy
"Don't Panic"
belairbrian
Alabama
Posted: 07/11/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I looked at the Zero G but then I saw that they are "Not recommended to be under constant pressure"
What does that mean? Do I have to turn off the hose at the campground valve when not using water?
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison
2009 Chaparral 278DS
Reese 16K Slider Hitch, Prodigy 3 BC
USAF Retired
WAR EAGLE
fj12ryder
Platte City, MO
Posted: 07/11/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, it sounds pretty obvious that you can't leave it under pressure all the time. Seems to be self-explanatory to me, but maybe I'm missing something.
ItsyRV
Desert SW
Posted: 07/11/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
There are two spot for common leaks. The first is the threaded connection to another threaded connection. The second is where the hose itself meets up with the metal/plastic end connector. The solution is based on which point has the leak.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
djousma
SW Michigan
Posted: 07/12/19 05:17am Link  |  Quote  |  Print  |  Notify Moderator
I used a zero-g hose for one season. Water started tasting like the hose at the start of the second season. I have since replaced the zero-g with Flexzilla hose and have had much better results. Biggest is that the hose is 5/8", not 1/2" like the zero-G so water volume is improved again(noticeable when showering), and second, there has been zero hose taste now since I started in April with these.
Since my waterbay is inside the basement of my 5th wheel, I bought:
These stay connected to the city water connection all the time:
90 degree hose adapter
3' Flexzilla lead in hose
Hose Quick connect
then just connect the 25' hose when arriving.
25' Flexzilla hose
50' Flexzilla hose
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
sgfrye
north carolina
Posted: 07/12/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
i discovered the zero g hose about a year ago and love it. easy to roll up and store.
i do not leave it under pressure. when we get to a campground i use it to fill my water tank and use it while we camp.
number one reason it always gives better pressure and if i develope a leak somewhere the pump kicks on and i know something is wrong.
 > Leaky waterhose
