RV.Net Open Roads Forum: Class A Motorhomes: Dometic Refrigerator Help?!
 > Dometic Refrigerator Help?!
fourdoras
Indiana
Posted: 06/28/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Rookie refrigerator question.
We are in the road for our first long road trip, and our Dometic freezer is plenty cold! Fridge “was cold when we left (38 degrees running on AC at our house). Temperature in fridge got up to 51 while driving today! Fins in fridge (older model Clss A 200 Holiday Rambler in great condition) were nice and frosty when we left house 6 hours ago. Now, we are connected to 50amps, and temp dropped to 48 so far after about 3 hours. We have small battery operated fan from Camping World running in there, and seems to be slowly cooling. But SLOWLY! And no frost on the fridge fins now. Freezer is still very cold at like 20 degrees and lower.
Any suggestions or help appreciated. We are BRAND NEW to RVing. So any help is greatly appreciated!
MountainAir05
New Mexico
Posted: 06/28/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.youtube.com/watch?v=zKxyHkp61jg
bob213
Fresno, CA
Posted: 06/28/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Was the fridge on lp when you were traveling?
midnightsadie
ohio
Posted: 06/29/19 05:14am Link  |  Quote  |  Print  |  Notify Moderator
put it on lp cools better and is your battery charged? most older units need a good 12v source even on shore power ,
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/29/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
X2??? These things are slow to cool and the freezer section needs to be close to 5 degrees to get the refrigerator section cold enough. Does the drain hose in the back of the refer have a plug in it? If not put water in the cup it’s in so hot air doesn’t get in until you can buy a check valve for the drain. 50 degrees is going to spoil your food so you can buy several pounds of dry ice to raise the temperature if you cannot get it to cool better.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
dougrainer
Carrolton, Texas
Posted: 06/29/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
1. When camped you MUST be Level
2. 120 or LP will not make a difference on cooling, UNLESS your CG line voltage is below 115 volts. If so, then switch to LP
3. A MUST tool for RV'ing is a Multimeter to test both 120 voltage and 12 volt.
4. In Transit, you DID have it on LP? Also, there is a drain line for the Evap fins to drain the water off when the fins de-ice. THAT tube comes out the back side of the refer where the outside refer access door is. THAT tube can allow hot air to migrate back up in transit and cause the lower section to raise in temp. You can temporarily block it off for in transit operation and unplug when camped
5. The normal operating temp of the Freezer is 10 degrees or colder.
The normal for the lower section is below 40 degrees
6. You just joined, so remember to always post Year and brand/model of RV and Brand and Model of appliance. You cannot get good help without that info.
7. IS the refer in a slide room? Doug
bjbear
Cold Lake, AB, Can
Posted: 06/29/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
fourdoras wrote:
Rookie refrigerator question........We are BRAND NEW to RVing. So any help is greatly appreciated!
I am assuming that you did not test your refrigerator on propane before leaving on your trip. The refrigerator will often not run on propane initially, especially if the propane has been shut off.
I have had a number of RVs over the years that required a couple of tries before it would work on propane. Here is the procedure I usually use when starting the fridge:
1) Start propane system.
  • Ensure RV is plugged into shore power (AC) and Batteries are charged
  • Turn on propane
  • light one burner on your stove briefly to test the propane system and ensure it is working correctly.
2) Start refrigerator.
  • Turn on refrigerator.
  • Set {MODE} to gas/propane.
  • Listen carefully. You should hear the igniter click a number of times followed by the sound of the burner.
  • If the burner does not ignite, you will get a failure indication (Ususally a red "F").
  • If it did not light, turn off the refrigerator and repeat previous steps.
  • The refrigerator should start (i.e. burner running) after no more than 3 attempts.
  • Let run on propane for 5-10 minutes, then switch {MODE} to 110VAC or AUTO. Check that the propane shuts off and the fridge continues to cool on 110V
  • Allow at least 12 hours for the fridge to get down to normal temperatures.
3) If refrigerator will not run on propane after 3 attempts.
  • Remove lower access door on outside of fridge.
  • Check that all wiring connections are tight.
  • Check that propane lines are tight. Some systems may have a small isolation valve that must be on.
  • Locate the burner and flue then have someone attempt to start the fridge while you observe from the outside.
  • You should see a spark at the burner, then hear the propane start to flow and then ignite.
  • If the propane starts, but the flame is weak or goes out immediately, it could be because the flue is plugged. Spiders love to build webs in the flue. These can be cleared by using a compressor to blow air up the flue.
  • If the propane still fails to work, then it is time for the manual and troubleshooting guide.
Hope this helps. Remember, you need to have the propane turned on while you drive. I always leave the fridge on AUTO so that it switches to propane as soon as the coach is unplugged from shore power.
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
tropical36
Southwest Florida_USA
Posted: 06/29/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
No clue as to your fridge or coach, so you might consider adding some particulars to you signature.
Most modern fridge versions will sw. over to LP automatically when without 120vac. If not, do so manually.
Some have had problems with the gas going out while underway, but there should be some sort of an alarm for that.
Do you have an inverter and is there an outlet behind the fridge for it, would also be a good question.
We do and run the fridge with it, while underway, rather than use propane. Also for short stops, but not for any length of time, as it will soon deplete the batteries.
Having an inverter on and leaving the fridge on auto, insures 120vac operation, but again, will deplete the batteries when not on shore power, genset or with the engine's alternator.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Rick Jay
Greater Springfield area, MA
Posted: 06/29/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
fourdoras,
Welcome to the forums.
You've received good info above. The only thing I'd ammend is this. Several said you have to have your fridge on propane while you travel, and generally that's true. However, if you had your generator running to run the coach A/C while travelling, you DON'T have to have the fridge on propane. It will get it's power from the generator.
A refrigerator will keep the contents cold a long time on its own without power. However, every time the door is opened, you let in warm air which must then be cooled. Which reminds me, you should check the seal around your fridge door as well. It's possible the seal is failing and allowing warm air in more quickly than it should. Here's a link describing the process to Check the Seals On Your Refrigerator & Oven.
Good Luck,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (22-Angel, Lexi96.org), 1 girl (17), 2 boys (19 & 16).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
