RV.Net Open Roads Forum: Tow Vehicles: New Ram/Cummins vs GM/Duramax on the IKE
Search only in Tow Vehicles
 > New Ram/Cummins vs GM/Duramax on the IKE
Page of 12
ib516
Canada - soon to be Costa Rica
Posted: 06/29/19 05:15am Link  |  Quote  |  Print  |  Notify Moderator
VIDEO
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
ib516
Posted: 06/29/19 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Interesting result. They didn't mention that the Ram had a slightly higher GCW based on the truck's configuration, I wonder how that effected things?
rhagfo
Portland, OR
Posted: 06/29/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
What is really interesting is that the GM is labeled 2500. but carries a GVWR of 11,300# making it a Class 3 (3500). Then the 10 speed with 3.42 vs 6 speed with 4.10. Keep in mind the total GCW for the Ram DRW will be heaver.
Now we have ford with a F350 SRW with a 10,000# GVWR and a GM 2500 SRW with an 11,300# GVWR, that should really muddy the waters!
FlatBroke
CO/AZ
Posted: 06/29/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Boogity, boogity, boogity! Let’s go racing boys!
Hitch Hiker
"08" 29.5 FKTG LS
ACZL
UPstate,NY
Posted: 06/29/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Didn't watch the vid, but amazes me that they cannot get the same specs for trucks to do a sxs comparo. Don't see how a fair comparo can be done otherwise.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
ShinerBock
SATX
Posted: 06/29/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
If you watched the first minute of the video, you probably would not be amazed about how they could not get the same truck with the same specs because they tell you why.
However, a true specs for specs purely does not exist especially now with 10-speed transmissions in the mix. A trans with more gears(i.e. 10 speed) and a taller rear gear ratio(3.42) is equivalent in terms of torque multiplication as a trans with less gears(6 speed) and a shorter rear gear ratio(4.10) due to the being able to have shorter trans gears with a better spread the more gears you have.
* This post was edited 06/29/19 08:59am by ShinerBock *
Ozlander
Rose Hill, Kansas
Posted: 06/29/19 08:58am Link  |  Quote  |  Print  |  Notify Moderator
A minus & a plus vs a plus & a plus.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
larry barnhart
wenatchee. wa usa
Posted: 06/29/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I enjoy the videos and whatever the results are is ok.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
IdaD
Idaho
Posted: 06/29/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I'm kinda maxed out on how many times I can watch some fat guys drive up a hill.
2015 Cummins Ram 4wd CC/SB
ksss
Eastern Idaho
Posted: 06/29/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
It appears to me that 16K isn't enough to challenge either pickup. GM a tad more hp and Ram 100 more pound feet of torque, and GM more gears. Be interesting to see how it shakes out at max capacity.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Page of 12
