RV.Net Open Roads Forum: Tow Vehicles: New Ram/Cummins vs GM/Duramax on the IKE
Search only in Tow Vehicles
 > New Ram/Cummins vs GM/Duramax on the IKE
Page of 12
FishOnOne
The Great State of Texas
Posted: 07/03/19 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Watched the vid again. RAM was 1 second slower not 2 as mentioned, no biggie just stating facts. The guesstimated distance of 2" behind center of rear axle, I am betting it's more.
Even if it was 2 seconds slower it would be within the margin of error. To get a real data set you would need a minimum of 30 runs to have a significant data set to see the real performance.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
ShinerBock
SATX
Posted: 07/03/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I agree. Heck, I think that even 15 seconds would be within a margin of error given how long the run is and dealing with traffic that may or may not cause you to slow down. Even letting off the accelerator for just a few seconds to adjust for traffic could cause you to loose a lot of momentum and time pulling that much weight up those grades.
Turtle n Peeps
California
Posted: 07/03/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
A sun dial would be within the margin of error with those guys. I'm on vacation so that's all I'm going to say. [emoticon]
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
larry barnhart
wenatchee. wa usa
Posted: 07/03/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
so I guess this video was like some of the news fake???? Looked real to me.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Posted: 07/03/19 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
They call it real world testing so they can't be held liable for the results they report
Hannibal
Tampa Bay Area
Posted: 07/03/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Either truck would tow our TT every bit as easily as my 5.4L F250 does. But if I were willing to spend close to $100k for a pickup truck to have 600 ft/lbs more torque than I need, I’d opt for the Chevy. I’ve already owned four Cummins powered Rams. Chrysler is trying desperately to hold onto a look that’s almost 30 years old. And judging by the number of vibration dampeners decorating the underside, they still haven’t perfected my biggest complaint about the Ram.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 103k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
RoyJ
Vancouver, BC
Posted: 07/04/19 02:15am Link  |  Quote  |  Print  |  Notify Moderator
RCMAN46 wrote:
Dynos:
Factory Rating/Dyno Measurement
Ram:
HP 385/338
TQ 900/828
Ford:
HP 440/387
TQ 925/806
Chevy:
HP 445/337
TQ 910/771
interesting when the same trucks were tested at the IKE run.
The D-Max has to be de-tuning itself on the dyno, no way it could perform like that while down 50hp from the Ford.
The Cummins is the over-achiever. I'd like see the actual dyno curve, perhaps the Cummins has a broader / fatter power band, resulting in more power under the curve.
The peak numbers only tell part of the story - when at less than peak power rpm, the Cummins may be producing more power than the other two.
Page of 12
