RV.Net Open Roads Forum: Oh shoot. The toilet foot pedal fell off.
 > Oh shoot. The toilet foot pedal fell off.
stew47
ohio
Posted: 06/30/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Well 3300 miles into our 4000 mile trip the toilet foot pedal fell off. Won’t go back on. We’re in Escanaba traveling to Frankenmuth. Any ideas how to fix or should I replace toilet?
Itchey Feet
Wyoming
Posted: 06/30/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Our TT came with a packet and in it was a breakdown of the toilet. It may have what you need to know in it. If not go online and give your make and model and it should be there.
My feet are fine as long as they are traveling.
BFL13
Victoria, BC
Posted: 06/30/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
BTDT. Undo the two bolts holding the toilet down and the water line, lift the toilet and re-attach the foot pedal. You can see how it works once you get at it. You might as well replace the flange seal if it is a foam one. Might not need to if wax.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Cummins12V98
on the road
Posted: 06/30/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
May want to mention what brand and model toilet you are referring to. [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
SidecarFlip
SE Michigan
Posted: 06/30/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Use the bushes......
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
myredracer
Langley B.C.
Posted: 06/30/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, what brand & model? After having issues with the foot operated water valve and also the ball valve on our Thetford Acqua Magic, we got a new Dometic 310. Much better toilet. Sold the Thetford on FB marketplace and had 3 people interested the next day and put the $$ towards the Dometic.
Easy to pull the toilets up but you want to replace the foam gasket any time you do that. If you have to go to an RV dealer or shop for that anyway, you might see what they have for a new pedal (if needed) or even a new toilet. I had the foot pedal on our Thetford off a couple of times and is not easy to get aligned correctly before pushing it back it place. Cheaply made IMO and can see why it'd come off.
If it's the Thetford Acqua Magic II, there is an online video from Thetford that has a young girl explaining how easy it is to re-install the pedal... [emoticon] I had a new foot valve to install in our old Thetford and couldn't quite figure out to put it back together properly. Took it to an RV repair shop and even the owner scratched his head at first. What a stupid toilet! [emoticon]
* This post was edited 06/30/19 11:40am by myredracer *
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
larry barnhart
wenatchee. wa usa
Posted: 06/30/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Hard to beat the dometic 310 change the bowl seal. Chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
stew47
ohio
Posted: 06/30/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I stopped at camping world and bought a domestic 310. When I talked to the parts guy he said parts were 80$ and pain to reassemble or 170$ on sale for the 310. So that’s what I’m gonna do this evening.
stickdog
Somewhere, USA
Posted: 06/30/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Throw away society but don't think I could hold it till Amazon could come through. Go with the new potty.
In
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
myredracer
Langley B.C.
Posted: 06/30/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
You chose wisely, lol! You'll love the 310. Just looks and feels more substantial.
