RV.Net Open Roads Forum: DSI light will not come on Winnebago Intent
 > DSI light will not come on Winnebago Intent
D1robert!
westminster,co
Posted: 06/30/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
The DSI light will not come on when trying to start the hot water heater. I have a Winnebago Intent.
dougrainer
Carrolton, Texas
Posted: 06/30/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
The light only comes ON and stays ON when it does NOT light. Doug
newman fulltimer
louisiana
Posted: 06/30/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Its in lockout mode from when you ran out of propane go outside and unplugged the black box a minute replug it in and try it again
Chris Bryant
Arden, North Carolina
Posted: 06/30/19 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
What? I think you misread the problem.
As Doug said, the light comes on for a fault, it is not an “on” light. Shut the propane and turn it on, after it doesn’t ignite the light will come on. Some boards light the light for a second when you flip it on, some don’t.
-- Chris Bryant
newman fulltimer
louisiana
Posted: 06/30/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
op stated No fault light . so board is either locked out or the diode is bad I understood what he is saying
Chris Bryant
Posted: 06/30/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Umm, the light comes on when it’s locked out, that’s why it is called a fault light.
dougrainer
Carrolton, Texas
Posted: 07/01/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
WHY do that?????? You just turn the Inside switch OFF and then back on. You do not have to unplug the Control module to reset a lock out. Doug
Wherever I happen to park
Posted: 07/01/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I always turned the inside switches off/on to reset lockout as well
There are two different programs. On one the DSI light will come on when you first flip the switch then go out when the board senses flame from what I understand. Note I've never seen one like thus but then not my business Just read about 'em.
On mine it is as many have said ONLY comes on if there is a fault. There are two different types of fault.. OVER TEMP (If the ECO T-Stat opens or you forget to re-connect it) and No Flame (The control board fails to sense flame. DOES NOT MEAN there is no flame.. Just means the board did not respond to it (Mine was rather bad about that till I put in a new board).
Home is where I park it.
polestar
middlesex, n.j.
Posted: 07/02/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
my fault light comes on when i have the electric hot water heater on, not all the time but but frequently. when that happens it turns the electric heater off. i have to turn every wsitch off and it will restart the electric. I never get fault light on when i use propane unless the is no flame.
hootgipper
Sarasota, FL
Posted: 11/04/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
We couldn't get our DSI light or water heater to come on. The issue was the water in the tank was still hot. It won't light/come on if the water isn't below a certain temperature.
