RV.Net Open Roads Forum: Tech Issues: Onan hot hot hot
 > Onan hot hot hot
onrecess
Boca Raton, FL
Posted: 06/30/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had trouble with my gennie dying for years. I spent a couple thousand at CW, they called in onan twice, kept it for many months. I pulled the fuel pump and replaced it. Runs great. I drove 200 miles across Florida, 90 degrees. No problems. Coming home, I stopped for gas. I shut it off (it exhausts under the fuel filler door.)mWhen I went to start it, no joy. I went to shange the oil. I could barely keep my hands on the cover to pull it. I had to hold the dipstick with a rag, it was too hot too touch. I drove a few minutes to let it cool. After ten or fifteen minutes it started right up. No problems after. I can shut it off and restart, but sitting long enough to fuel up it gets too hot. I looked under it to see where air goes in... There is a perforated metal part where the oill filter and drain is. There is metal plate behind it (touching). There's a pan that covers almost the whole bottom, and the perforated part disappears over that, with a 2" gap the length. Is it open under? I assume there is a fan, is it belt driven? Seems awfully hot. Is this normal? Does your gen set get that hot?
Tom Anderson
2005 GeorgieBoy 35
onrecess
Boca Raton, FL
Posted: 06/30/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the carb altitude, it is set to 0, where I am. I started it, there is a lot of air coming out the air exit by the muffler. Someone somewhere mentioned a summer/winter switch, but I don't see one.
TEXAS
Centerville Tx
Posted: 07/12/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Onan has been building generators since 1925. Would be nice to know which one you have. Model and serial number would help.
This is the reason generator techs like myself left this site. People asking for help. But not telling us what they have.
dougrainer
Carrolton, Texas
Posted: 07/12/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Your Onan is AIR COOLED. Also the Altitude adjustment is for the Fuel/air mixture at the CARB. Has nothing to do with cool air circulation. Doug
apr67
Tallahassee, Florida
Posted: 07/12/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Mine (5.5k hgjab) is the same way. It gets hot as hell under the cover. Onan has a procedure in the installation manual to test that the hot exhausted air isn't being re-ingested for cooling. However I personally don't have the tools for that.
2017 Thor Hurricane 34J
Gone-2014 Chevy Express 3500
Gone-2016 Jayco White Hawk 32DSBH
Gone-2013 Keystone Bullet 294BHS
Gone-2007 National SurfSide 34DE
Gone-2006 ForestRiver Sunseeker 2900LTD
Gone-1994 Fleetwood PaceArrow
Gone-1978 Kit RoadRanger
DownTheAvenue
Sunny South
Posted: 07/12/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
One thing to think about is that the generator should be disconnected from any load and run to cool off before shutting down. Shutting it down immediately while under load just makes more heat to be dissipated.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/12/19 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
HOT HOT HOT?
Push ambient air into the generator compartment
and...
it cures the ambient generator compartment hot tamale syndrome.
onrecess
Boca Raton, FL
Posted: 07/12/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
The gennie is a 5500 Marquis Gold HG JAB.
Thanks for the fan post, I am considering that and an air scoop under the coach.
And the cooling off. I've never done that.We are usually running two ACs, because of the heat in FL and back and forth to Texas. I'll be sure to do so in the future.
* This post was edited 07/12/19 04:02pm by onrecess *
 > Onan hot hot hot
